bluestreak
bluestreak
hey guys new to the site and have a question just bought a 06 gto and have installed new headlights with HIDs and they flicker and pass. side turns off randomly i have put in code eliminators and wonder if i should still disable the DRLs or will the code el.fix the problem THANKS
No idea what code eliminators are, but you need to pul your DRL relay. The wattage is not enough and it can ruin your bulb/ballast. A flicker is usually an indication of a ballast problem so see if you can swap them if the DRL doesn't do the trick.
