Pontiac GTO 2004-2006 The Modern Goat
Hood release doesn't work....
Old 11-13-2010, 07:58 AM
va79ta's Avatar
Default Hood release doesn't work....
A friend of mine contacted me last night saying his hood release "was stuck." After a few minutes, over the phone, it seems the inside release doesn't work. He's bringing the car over this morning to see what we can figure out. I don't know this car. Is there anything special I need to look for? I'm hoping the cable popped off at the release. I don't really want to be crawling under the car to get behind the bumper. Thanks for any help you guys can provide.
Old 11-14-2010, 05:54 PM
va79ta's Avatar
UPDATE: It turned out that there was no grease on the release spring. A little bit of lube, and the hood pops without a problem. I'm glad I didn't have to tear anything apart.
Old 11-15-2010, 10:28 AM
JustAnotherLS2's Avatar
Dont see any logic behind lube fixing your problem, but at least you fixed it.
Old 11-28-2010, 12:55 AM
LS2-TOY's Avatar
I need to try some grease on mine. I was at HRP in Houston and wanted to let my engine bay cool off between runs and my damn hood release wasnt working.
Old 12-05-2010, 12:29 PM
cbonsall's Avatar
had this happen to my 06 when it was unhder warranty, took it to the dealer, they never would tell me how they got it open.
Old 12-05-2010, 01:04 PM
necrocannibal's Avatar
I had this issue and to get it open have someone push down on the hood while you pull the lever. I just had to adjust the hood stoppers down a few turns so it wasnt pushing against the release so hard.
Old 12-11-2010, 12:25 PM
Ls2Goat21's Avatar
I had this happen once too. I came back 5mins later and worked fine, hasn't done it since.
Old 12-11-2010, 02:01 PM
V-seriesTech's Avatar
....if you suspect your hood lever will fail soon, i strongly suggest you change the release cable. it comes complete, and is very easy to change if the hood is already open.
Quick Reply: Hood release doesn't work....
