Pontiac GTO 2004-2006 The Modern Goat
Trans Fluid Leak
Old 12-02-2010, 11:41 AM
slogoat's Avatar
Default Trans Fluid Leak
I recently noticed some drops in the garage, crawled under the car and found this. Its where the bell housing connects to the back of the motor. Its a pretty slow leak, about a drop a day. Is it some sort of seal, any input or thoughts would be appreciated.
Uploaded with ImageShack.us
Old 05-23-2011, 09:17 PM
Roel Aguilar's Avatar
Did you figure it out yet? It's been a while since you posted up.
Old 05-24-2011, 04:08 AM
slogoat's Avatar
Yeah it's actually not tranny fluid, it's the rear main seal. Just one of those things i'll fix when i have to replace the clutch.
Old 05-24-2011, 12:02 PM
gmgearhead's Avatar
its probably not the rear main but the back of the oil pan. The gasket is known to leak.
Old 05-24-2011, 09:21 PM
slogoat's Avatar
Thanks for the input, either way it's not leaking too bad so i'm just going to keep a close eye on it.
Old 05-25-2011, 12:09 AM
Xtreme864's Avatar
My Z is doing the same thing. It's such a slow leak that I don't even have to pay attention to it. I just check the oil every 500 miles or so like I always do and add accordingly. I have to add a quart IF THAT inbetween oil changes. My diff is leaking even slower, and its not even coming from the gasket, i've noticed a little fluid on the u joint but it's a really thin layer, doesn't even drip. I figured that's probably the result of using synthetic fluid when I got the new gears put in.
Quick Reply: Trans Fluid Leak
