PCM / BCM Start Issue
Ok, ive had this issue for 2 weeks now and can not figure it out
I just got done with my procharger install. I go to start the car and it wont turn over but it throws the SVS, Check Oil, and Fuel Gauge error. It also says trac off and wont turn it back on.
PCM and the BCM get power/ground and puts out power/ground.
The OBD port gives my scanner power but no signal.
EVERY fuse in the car is good.
Swapped the relays around.
Jumped the car to 13.5v because the battery got low after a while.
Checked the wiring for any obvious cuts or shorts.
The PCM was relocated (BAT was connected )
Ideas, im running out of hope here. Im really starting to wish this was the Fbody setup...
