Pontiac GTO 2004-2006 The Modern Goat
04 gto guys come on in
Old 12-14-2010, 09:22 PM
ebk06's Avatar
Default 04 gto guys come on in
Im getting ready to install my motor in my swap. There are a bunch of small metal tubes coming off and around the throttle body. Can someone post up some pics of where these are connected to?
thanks in advance
Old 12-15-2010, 07:40 PM
ebk06's Avatar
Damn, no one can go snap a quick picture for me?
Old 12-15-2010, 07:52 PM
Roman nj.'s Avatar
04 gto guys come on in-engine-bay.jpg It's too dark and dam cold to take a pic now but I google imaged a 2004 gto engine and found this. hope it helps
Old 12-16-2010, 10:08 AM
batboy's Avatar
The top tube on the passenger side connects to the vent tube on the valve cover. The two lower tubes are for coolant hoses. One runs to a barb on the top of the radiator. The other goes to a T fitting on the crossover tube that connects to the two heads in front. I have done a coolant bypass, so mine are no longer connected. Supposed to add a little power without the cooling lines attached to the TB. Just connect the rad to the crossover line directly.
Old 12-16-2010, 06:11 PM
ebk06's Avatar
Thanks batboy. I couldnt find a picture anywhere that clearly showed what went where.
Quick Reply: 04 gto guys come on in
