ls2 cam sensor harness issues HELP
I bought an 06 ls2 gto engine harness off here... i ended up buying all the sensors from gm.... which included a cam sensor harness... one problem arrose... the cam sensor mated with the cam sensor harness just fine but when i went to plug the cam sensor harness into the ls2 engine harness ... it wouldnt connect... its like the slightly different ot something. dould i be missing an additional harness or do i have the wrong cam sensor harness . The engine harness part number reads that it belongs to an 06 manual gto.. and the part number on the cam sensor harness is 7501 i believe... If possible can some one give me part numbers or pics of the plugs where the harnesses connect? thanks for any help guys
