Changing radiator????
It's really easy. Disconnect the hoses and plugs for the fans. The fan shroud lifts up after pushing a couple of little clips. The radiator also just slides up with the AC condenser. You don't have to disconnect the AC as the lines can be carefully bent a little.
Here's a pic showing one of the tabs for the fan shroud you push down on
