Pontiac GTO 2004-2006 The Modern Goat
2004 GTO Electrical Problem With Wipers & A/C Panel Lights, Radio
Old 07-26-2011, 10:19 PM
1Ls1's Avatar
Exclamation 2004 GTO Electrical Problem With Wipers & A/C Panel Lights, Radio
got a 04 gto, windshield wipers only work when you first start the car up for the first 3 seconds, and the a/c button light along with the rear defrost light only work for the first 3 seconds of the car being on, but the a/c works even when the light turns off, also when you pull the key out of the ignition, the radio does not turn off. You actually have to push the "off" button to turn it off, New BCM (body control module) still same thing. dealer doesnt know.
Old 07-27-2011, 11:02 AM
Joeyelbows's Avatar
Refer to the sticky post above. That's what it probably is.
Old 07-27-2011, 11:26 AM
1Ls1's Avatar
the ignition switch?
Old 07-27-2011, 02:34 PM
Now you have my attention
GTOSE's Avatar
Warmer.
https://ls1tech.com/forums/pontiac-g...ights-etc.html
Quick Reply: 2004 GTO Electrical Problem With Wipers & A/C Panel Lights, Radio
