Pontiac GTO 2004-2006 The Modern Goat
air temp sensor
Old 10-31-2011, 06:28 PM
Ian06GTO's Avatar
Default air temp sensor
check engine light is on and the code is for the air intake temp sensor high voltage. Is that sensor located in the maf???
Old 10-31-2011, 07:30 PM
bridges's Avatar
Yes. It is on the maf.
Old 11-01-2011, 09:57 PM
impulsegoat's Avatar
05-06's its in the maf. 04's it's in the intake tube. I'm assuming you have an 06 based on your s/n.
Old 11-02-2011, 10:06 AM
svede1212's Avatar
. . . and info below his name.
OP, first check your MAF plug.
Quick Reply: air temp sensor
