Pontiac GTO 2004-2006 The Modern Goat
Does any one knows...
Old 01-10-2012, 02:01 AM
CAMSTER's Avatar
Default Does any one knows...
Any one makes a custom engine cradle or 8 frame for our 04/06 gto?
Old 01-11-2012, 08:37 AM
mark21742's Avatar
Really no need for it.....I was shocked by how light that big peice of metal actually is.
Old 01-11-2012, 11:26 AM
black00TA's Avatar
the front end is a heavy beast, ditch the skid plate and that will save a bit
Old 01-11-2012, 01:36 PM
mark21742's Avatar
The big problem when it comes to losing weight off the GTO is most of the weight is in the sheetmetal itself....I just cut the rear floor/ frame/ wheel wells out of of my 04 and was shocked at how much the floor and sheetmetal framerails weighed....I'm sure this is the same for the front too. I've had the whole cradle and front suspension out of mine a few times and none of yhe parts them selves ate all that overly heavy, so that just leaves the body shell and sheetmetal framework.
How far do you want to go to lighten your car? I should be atleast another 100 lbs lighter after my 9" solid axle, 4link and back half swap!
Old 01-11-2012, 03:03 PM
my first GTO's Avatar
Stay tuned I do know of something in the works very soon.....
Old 01-11-2012, 04:50 PM
kjhallex's Avatar
Keep us updated!
Old 01-12-2012, 01:48 PM
magnum-gto's Avatar
Yes.....I invested about an hour last night to the project.
Old 01-12-2012, 03:46 PM
Jan, as I see Tony did as well.....Jan can you call me with your shipping address when you can....Thanks
Old 01-12-2012, 04:29 PM
CAMSTER's Avatar
Originally Posted by kjhallex
Keep us updated!
PM me asa you know...
Old 01-12-2012, 04:57 PM
CAMSTER's Avatar
I want to remove 300 pounds, even after the roll bars, but the great deal of goodness is added to a car when is made easy to work on, and have room around the engine, on my engine craddle, i made it with removable center brace, so i can remove it for bearing or any other inspection, with out having to lift the engine or lower the frame.
I have removed; the belly pan, will change seats for racing light weight pair, with the roll-bars can take out the gas tank brace/ gone is the hitch reciver, the drag pack does remove 77 pounds, another info i want is for lexan windows, anyone knows connection, pls post it, thanks.
I did get a big set back with the lsx block, as far as weight
Old 01-12-2012, 05:08 PM
CAMSTER's Avatar
Will you pls post some pix of the back of your car, i assume you have some wide tires and wheel set in there, i have always like to see more tire tours the inner side of the back of the gto, with some good size dich on the wheeels, thanks.
I had a reasonable suspition that the gross over weight in our cars, was due to the unitise body, itself..You confirm this..
Old 01-13-2012, 05:20 AM
mark21742's Avatar
I already had the wide body, but had to adjust the body roll for the new wheels and tires.....18" wide 15's, and for now 31-18.50 15's till I wear these tires down then going with 33-22.50 15's
Still need to cut and raise the tunnel and build the cage...main hoop should be here beginning of next week
Money shot!
Old 01-13-2012, 01:23 PM
CAMSTER's Avatar
Default Mark, thats radical...
Thanks for shearing those pix, looks like a lot of fab/hard work, but the massive tires, man thats awsome... subscribing to more info and pix as you progress... thanks again, David... PS, You may end up with record setting wheelies for a late gto...imo..
Old 01-13-2012, 01:29 PM
mark21742's Avatar
I'd LOVE to do I wheelie
Old 01-13-2012, 05:38 PM
To big for me....
Old 01-13-2012, 08:57 PM
mark21742's Avatar
Hey Frank. What was your race weight and HP this past season?
I love your car
Old 01-13-2012, 11:17 PM
3595 and 1,056 to the wheels at 8.99@154
Quick Reply: Does any one knows...
