Pontiac GTO 2004-2006 The Modern Goat
Gto build
Old 07-02-2012, 05:02 PM
twgoodspeed's Avatar
Default Gto build
Hi everyone I'm building a Gto/monero clone and I picked up a salvaged Gto, I need a core support up to driver frame rail to the strut tower cause the corner is all bent up, I also need a drivers front fender and all lights for now. Eventually when it's done I'll need better axles l, sway bars, polyurethane bushings as I want to use this as s corner carving beast as well as drive it to a random track and run mid to high 11s n drive it home but for now first things first. If anyone has what I need pm me please
Old 07-03-2012, 04:01 PM
joeyagls1's Avatar
I have a 2004 rear bumper and a spoiler if yours are in bad shape. Other than that good luck on the rest friend.
Old 07-03-2012, 11:13 PM
O-FiveCC's Avatar
I've got a nearly mint OEM driver's side headlight. I have a passenger headlight as well, but a tab is broken
Old 07-05-2012, 12:33 AM
mark21742's Avatar
Wish you would have posted this a few months ago....I cut my 04 GTO up and built a full tube chassis under the body and had all the subframe sheetmetal......but just scraped it all
Old 07-05-2012, 12:35 AM
mark21742's Avatar
I do have some front and rear suspension parts and big brakes if you cant find the parts any closer to your location. I'm in PA, so shipping might hurt for bigger parts
Old 07-15-2012, 02:00 AM
I got a 05/06 rear bumper Realy needing lights driver fender and cot support with a lil bit of frame wall on drivers side 3197505322 if anyone got anything
Quick Reply: Gto build
