Pontiac GTO 2004-2006 The Modern Goat
Gauges goin crazy on dash
Old 10-12-2012, 08:58 AM
joeyagls1's Avatar
Default Gauges goin crazy on dash
All my gauges are out of wack, it is getting colder here in idiana, so I do not know if that has to do with it, but my MPH, says I am going 150-200 in park, rpm tack vibrates a lot does not stay steady. Computer problem?
Old 10-12-2012, 10:45 AM
thehazz12's Avatar
Common issue. You're getting some resistance issues from your BCM wires rubbing on sole metal behind the glove box. Wrap 'em up real good, and you'll never have that problem again.
There's a sticky over on ls1gto if you're wanting to check out a more detailed write up with pictures.
Old 10-12-2012, 11:59 AM
Tim94gt's Avatar
+1. Pull out the Glove Box and check the harness for any damage.
http://www.ls1gto.com/forums/showthread.php?t=377773
Old 10-12-2012, 01:54 PM
bnvus's Avatar
Could be this old TSB also.
Speedometer Erratic Movement, Fuel Gauge Does Not Go to Full After Filling, Engine Coolant Temperature Gauge Reads Hot and Coolant Temperature Light Illuminates (Reprogram IPC) #05-08-49-003 - (Jan 20, 2005)
2004 Pontiac GTO
Built Prior to VIN Breakpoint 4L296011
Condition
Some customers may comment on one or more of the following conditions:
• Speedometer jumps erratically. Gauge may go up to 200 MPH or not return to zero.
• Fuel gauge does not move off empty when tank is full.
• Engine coolant temperature gauge reads hot and coolant temperature light illuminates.
These conditions may be intermittent.
Correction
Technicians are to reprogram the IPC with an updated software calibration. This new service calibration was released with TIS satellite data update version 1.0 available January 10, 2005. As always, make sure your Tech 2® is updated with the latest software version.
Important: Vehicles built after the VIN breakpoint must have the IPC replaced to correct these conditions
Old 10-13-2012, 03:38 PM
joeyagls1's Avatar
I will check the wires behind the glove box or under the steering column where I can unlatch that little cover?
Old 10-14-2012, 06:33 PM
6PntHo's Avatar
Under the glove box.
Old 10-14-2012, 09:44 PM
joeyagls1's Avatar
alright i will check it out
Quick Reply: Gauges goin crazy on dash
