Pontiac GTO 2004-2006 The Modern Goat
6.0L in an 04 gto
Old 04-21-2013, 08:54 PM
vetklr's Avatar
Default 6.0L in an 04 gto
Do you need the converter box to go from a 24 tooth wheel to the 58 tooth wheel in an 04 gto I am putting a 6.0 in the car Any info would be great
Old 04-21-2013, 09:20 PM
409CISecondGen's Avatar
If you use an LS2 from a GTO it will come with the 24x reluctor wheel while Corvettes will have the 58x. I believe that your crank should be stamped with a 24 or 58 on it.
Old 04-21-2013, 09:51 PM
redtan's Avatar
Depends on what the new engine comes with. Some came with a 24, some with a 58 depending on the donor model.
Old 04-22-2013, 10:43 AM
outkast6991's Avatar
Year of the motor as said above. I have an LQ9 in mine. It had a 24x wheel already
Old 04-23-2013, 06:06 PM
george g's Avatar
04 GTO's come with the 24 tooth wheel.
Quick Reply: 6.0L in an 04 gto
