416 LQ9 Stroker build 04 QSM
Well fought one problem after another... first a no spark issue that I still haven't found the cure of but got the car running....
ANd now my freshly rebuilt trans is stuck in reverse... the shifter shifts thrue all the gears but if you let out the clutch in any gear but reverse it will kill the motor...
But here is an idle vid with the x pipe and borla xr1`s
