2005 Alternator wiring
[B] Alternator signal wires on 2005 GTO Orange and White . I want tie my alternator wiring from 1972 Nova Blue and white wires into these these .
Anyone know what wires to use ?
Thanks Bill ...
Thanks Bill ...
Bill, why do you want to tie those wires to the GTO wiring? Are you using the Nova alternator still?
When I swapped the GTO engine into my '69 Camaro, I didn't use any of the Camaro alternator\charging wiring other than a charge wire from the alternator to the battery.
I removed the voltage regulator on the core support and left the connector with the blue and white wires just hanging.
Not sure you can read this diagram, but this is part of the GTO charging system.
