Pontiac GTO 2004-2006 The Modern Goat
Using BCM off another car?
Old 06-25-2014, 06:20 PM
Freefallin's Avatar
Default Using BCM off another car?
I want to swap over a BCM of another similar car to mine but I'm hearing that it will not be programable to my ECU since BCMs can only be programmed once.
However, I also hear that it is possible if I got the BCM security code of the donor car.
Can anyone that knows for a fact plz shed light on this?
Old 06-26-2014, 08:57 AM
J-Rod_Almighty's Avatar
You can use another GTO's BCM But you must have the code to do so to be able to link it.
Quick Reply: Using BCM off another car?
