NEW Hinson Motorsports 800HP & 1100 HP Driveshafts and Engine Mounts
#41
Our engine mounts are a performance blend of polyurethane that is unique to us. It is much firmer that stock but not so firm that it transfers a lot of additional vibration. We also have integrated an interlocking laser cut stainless steel core that links the upper and lower portion of the mount to one another that keeps the mount from failing. "If" the mount were to fail it would still maintain a connection between your engine and engine cradle. In short they are a lot better.
Thank you for the continued feedback. Its very much appreciated. The tranny mount will be a match to the engine mounts from a firmness standpoint and it is also an interlocking design.
There is no harm in running our engine mounts with a new OEM trans mount. The mounts make a big difference in overall feel of the car especially if your a M6.
General Update
At this time we are building a mold for the mount to hopefully test the M6 mount by the end of the month or first of next month depending on how smooth everything goes. This is a soft deadline as I cannot tell the future. The automatic mount is a little further behind than this but it is in the works and will be made as well.
If anyone is going to Rod Run in Pigeon Forge on April 16-19 I hope to have a finalized sample to show anyone that wants to see one in person.
General Update
#45
Hinson Motorsports is proud to announce a more powerful, and less expensive option for your late model GTO driveshaft. The Hinson Motorsports Sportsman (800hp) and Drag Edition (1100hp) 1 piece aluminum driveshafts. These driveshafts feature a dual pattern flange to support the 04, 05, and 06 GTOs all in the same shaft. The yokes are forged steel, and utilize 1350 U-joints. We also offer upgraded Forged Chromoly Steel yokes for the hardcore racers. These upgraded chromoly yokes can withstand even the hardest launches. With a critical speed rating of 160mph, it exceeds the competition for a better price. Stop by today at www.hinsonmotorsports.com and pick yours up today and enjoy same day shipping in most cases and no extended build times like other manufacturers.
Hinson Motorsports Sportsman 800hp Driveshaft
Hinson Motosports Drag Edition 1000hp Driveshaft
Upgraded Forged Chromoly Yoke
#49
This a good estimate. I will try to have an exact weight in days to come, but it is considerably lighter than stock.
Thanks for the response 2QWK.
#52
#53
We are certainly looking forward to it being something good for us and the GTO community.
When you get ready give me the opportunity to help. I've recently replaced most of my suspension and driveline components, and it made a huge difference.
#54
^mine has about 57k on the clock and ive noticed the rear settling, so i got a lot of work ahead of me. Probably gonna throw in new motor mounts and trans mount while im at it.
I've noticed under heavy throttle i can feel the shifter (manual) shift with the higher RPM freaked me out the first time it did it. I just havnt had the time to park it and really give it all the things it needs to be a more solid car. But its also my DD and the other car got all the go fast goodies and attention. So little time haha
#56
This a great product. I just installed them this last weekend and the feel of the car is very much improved. The car feels more positive and Hinson motorsports is great to deal with.
#57
Thank you for the opportunity to work with you and the great feedback. Glad you enjoy the product. Be sure to pick up one of our trans mounts that will be available soon.
#58
Be sure to keep an eye out for our trans mount that will be available soon as well. Thank you for the feedback. It's very welcome on new products.
#60
It really depends on the shape of your car. IMO struts and springs or coilovers, upper strut bushings front and rear, radius rod bushings, andn then whatever else is worn out on the car.
