Pontiac GTO 2004-2006 The Modern Goat
Hinson Motorsports Short Throw Shifter for 04-06 GTO, and Transmission Mount Update
Old 06-16-2015, 08:58 AM
HINSON Motorsports's Avatar
Originally Posted by s/c'd cav
what keeps it centered if there is no springs ? the stock sucks and doesnt center well either
A series of washers that compress under load. The are designed to last for very long times under high loads. They are mos commonly used to hold props on airplanes.
Old 06-22-2015, 11:22 AM
Bump.
Old 06-29-2015, 10:27 AM
Bump.
Old 06-29-2015, 01:18 PM
Default HINSON Motorsports GTO Transmission Mount Update
As a lot of you know, we are in the final stages of our production run for the 04-06 GTO performance transmission mount (NOT AVAILABLE YET). The transmission mount has been developed to match our interlocking engine mounts that many of you already have. If you are interested in purchasing our engine mounts, they are available currently on our site. (http://www.hinsonsupercars.com/s-496...n.aspx#Chassis) Our new transmission mount will also have the interlocking stainless steel design that has been so successful in our engine mounts. The urethane blend is perfectly matched to our engine mounts to help keep your engine and transmission in place while you put the power down. I am starting a notification list of people that want to purchase as soon as the item is available. In order to get on this notification list, you will need to email me your contact information. The price for this item has not been set, but it will be known by the time this notification goes out.
*We do not need "test cars" for this item. It has been tested, so please do not bother me with emails like this.
To receive a notification email chris@hinsonmotorsports.com the following information:
  • Name
  • Phone #
  • M6 or A4
The final version of the mount will be black urethane. The blue was done for illustration purposes.
Installed.
It is an interlocking stainless steel design that matches our engine mounts. The triangle in the center was for mock up purposes. The top and bottom sections are floating in the urethane to help dampen vibrations.
Old 07-20-2015, 12:35 PM
Pair this with our new 1 piece driveshaft to really step up your GTO driveling.
Old 09-15-2015, 11:37 AM
In stock for the auto (A4) and manual (M6) transmissions.
Old 09-24-2015, 11:29 AM
Back in stock. Get yours today.
CLICK HERE TO PURCHASE
Old 09-26-2015, 02:58 PM
Felix C's Avatar
Nice to see new stuff for the GTO. Means the car is not dead to the aftermarket. I do not mean the LS1/2, I mean other GTO unique items.
Thanks
Old 09-28-2015, 10:28 AM
Thanks
It is a tough market because there were so few of these made, and only a fraction of those are still around. I am a passionate GTO owner and if I can find a way to make something better and bring it to market at a reasonable cost we try. If people continue to by the things we produce we will continue to bring new things to market.
Old 10-20-2015, 10:34 AM
Bump for in stock.
Old 10-23-2015, 09:58 AM
Weekend reminder.
Old 11-06-2015, 11:12 AM
  #32
Friday reminder.
Old 12-27-2015, 12:00 PM
  #33
ledzepp3's Avatar
I just got my short throw put on my '06. It took longer than I expected, even after reading the instructions and seeing what it entailed, but it was definitely worth it. The shifter doesn't feel like stirring a jar of peanut butter anymore, and feels solid. Reverse is a little stubborn sometimes, but you guys did a kick *** job on the shifter.
Everything came off as instructed (with some cursing), all the new parts bolted on, and it works like a charm. Now I've got some motor and tranny mounts on the way too
Old 12-30-2015, 10:52 AM
  #34
Thanks for the opportunity to earn your business, as well as the great feedback. We are always glad to see pleased customers. Give the shifter a few hundred miles and it will work even better, reverse especially. Definitely get the engine and trans mounts as well. It's amazing how keeping your driveline in the right place will effect your power transfer and shifting.
Old 01-12-2016, 10:10 AM
  #35
To the top.
Old 01-15-2016, 10:21 AM
  #36
Old 01-18-2016, 10:28 AM
  #37
Bump for in stock.
  #38
To the top.
Old 01-26-2016, 11:15 AM
  #39
Also available with a white shift ball.
Click Here For Pricing & Purchasing
Old 02-04-2016, 10:46 AM
  #40
In stock.
Quick Reply: Hinson Motorsports Short Throw Shifter for 04-06 GTO, and Transmission Mount Update
