2005 GTO Rear brakes dragging
We have a 2005 GTO purchased in January with 40,000 miles on it. A couple of months after buying it, I did front brakes, and noticed the rear brakes were worn thin.
Seemed odd, so I swapped out the pads at the same time.
Intermittently, it tugs after stopping, and the rear brakes sometimes squeal a little, as it takes off. There is also more brake dust on the rear than the front. I attributed this to cheaper brake pads.
Today, after a quick drive around the block, I checked the brakes with thermometer. Front 168/183 rear 396/375.
Any ideas where in the system the issue is?
Thanks
Thanks
It could only be one or two things: either the parking brake shoes are dragging or the pistons in the rear calipers are sticking and you need to clean/rebuild them. Both jobs are easy to do and don't cost much money. Rockauto has everything or your local auto parts store probably has the parts too. When finished, do a complete flush of that old brake fluid.
Download the whole service manual here (follow instructions on page): http://www.ls1gto.com/forums/showthread.php?t=736178
When I did the pads, the pistons pushed back smoothly, and I find it hard to believe that both sides would stick, equally and simultaneously.
Since both rear brake lines are separate, all the way to the big abs module, I am wondering if the module itself may have a leaking solenoid or something that is lightly activating ABS and causing a drag? I was hoping someone may have experienced this.
We never use the parking brake, so I guess I need to look into that.
Thanks
That's because the admin there sucks and they delete everything... Ls1gto.com is doing a death rattle; sorry. Click the download button in the upper right corner for the whole download.
https://www.dropbox.com/sh/bf4xvfch6...a/Uploads?dl=0
Thanks.
