Pontiac GTO 2004-2006 The Modern Goat
5.3 4L60E swap into 04 GTO
Old 09-27-2016, 11:45 AM
gingerbredman00's Avatar
Default 5.3 4L60E swap into 04 GTO
Long story short I have an angry little 5.3, 4L60E, harness, ECU, ect.. (everything from the engine bay) I pulled from a truck I sold as a roller.
I just picked up an 04 GTO as a roller and would like to "build" this.
I have the GTO oil pan, alternator, water pump, A/C condenser, and the GTO still has the wiring harness.
Essentially Everything was left in the GTO except the long block, T56, and driveshaft.
Other than the driveshaft, shifter, transmission lines, and transmission mount I believe I have everything to do the swap.
So far I have about $60 out of pocket into everything, so it makes sense to put this together and possibly sell the car, or spray the **** out of it and have fun.
If anyone on here has done this type of swap am, I missing anything?
Old 09-27-2016, 03:17 PM
Buzzmanb12's Avatar
Reluctor wheel on your 5.3 maybe, they are different from 04 to 05/06 because 04's use ODBII vs CAN BUS for 05/06 GTO's...
Quick Reply: 5.3 4L60E swap into 04 GTO
