Pontiac GTO 2004-2006 The Modern Goat
05 LS2 GTO High Flow Induction systems in stock !!!!!
Old 05-05-2005, 07:08 PM
Mike @ New Era's Avatar
Default 05 LS2 GTO High Flow Induction systems in stock !!!!!
OK guys , they're in stock and you can now order them off of the website at www.neweraperformanceparts.com . The first supply is limited so order at will because after this first batch is gone , it will be about 1-2 weeks before we can get more in due to the fact that one of the kit components takes quite a bit of time to manufacture . Unfortunately we can not do a group buy , sorry guys . I still think that you are getting a nice kit made with the highest quality components for a good price at $219 .
The "New Era" intake is constructed from the highest quality components on the market today . It features 4 Ply High Temperature 4 inch diameter silicone couplers , a T-304 stainless steel tube powdercoated "Black Chrome" (Exclusive) and utilizes a K&N high flow air filter along with T-304 stainless steel (aircraft grade) liner clamps to prevent any tearing of the silicone couplers and allow you to tighten them up tight . We dynoed this kit on a completely stock 05 GTO with only 1500 miles on the odometer and picked up 8 lbs. of torque and 7 horsepower at the wheels switching from stock on the dyno with back to back runs , we feel the results will more than double with time as the computer has a chance to relearn due to the complicated new computers in the 05 LS2 . Those numbers and the high quality components this intake is constructed from should say enough , especially with a very competitive price tag like this !!! All components in this kit carry a LIFETIME WARRANTY .
Thanks ,
Mike
sales@neweraperformanceparts.com
585-865-1832
Old 05-05-2005, 07:13 PM
Moderator
xp3nd4bl3's Avatar
Looks awesome! Like you said I'll be there's more gains after you put some miles on it. Nice piece.
Old 05-06-2005, 11:55 AM
CSiJason's Avatar
You wouldnt mind snapping a pic of how the incoming pcv air tube connects on that thing? I guess you remove the stock hard nylon line and replace it with a flexable rubber one?
Old 05-13-2005, 11:42 AM
Dwayne98c5's Avatar
Does that set up use the K&N cone filter part # RE-0950?
Old 05-20-2005, 11:45 PM
AXE20's Avatar
Its good put try to put a cover to isolate it from the engine heat.
Old 05-22-2005, 09:23 AM
ULTIMATEORANGESS's Avatar
looks top notch.
any tuning needed?
Quick Reply: 05 LS2 GTO High Flow Induction systems in stock !!!!!
