Shift Light-2005 Ecm
Tach Signal -2005 ECM
To all that want to Install a real Shift Light (AUTO METER) The wire is
a Brown, pin 48 on the c1 conector from the ECM
which is the top upper most conector on the ECM. C2 is the middle conector, and the bottom is C3.
The Circuit Number is 121 and called - Tachometer Signal
C1 conector
Pin 47- not used
pin 48- tach. Sig
pin 49-50 not used
Info FromPage6-384 Volume 1 of 2 SERVICE MANUAL
C1 conector
Pin 47- not used
pin 48- tach. Sig
pin 49-50 not used
Very easy, Yes, Install less 1 hour 3m tape light to steering Coluum. Green to ECM, RED to 12 volts, Black to ground. Can change RPM by changing pills. Less than 70.00
