Pontiac GTO 2004-2006 The Modern Goat
My car whistles ?????
Old 09-29-2006, 10:53 PM
GOGOGTO's Avatar
Default My car whistles ?????
Somewhere around 48 to 55 car car whistles. It's not the windows but I don't know what it is. It's driving me crazy!!!!! Does anyone know what this is ???
Old 09-30-2006, 04:23 AM
k1200lt's Avatar
I think there is an issue with air coming in from the outside mirror base plates. Is it coming from that area?
Old 09-30-2006, 09:35 AM
GOGOGTO's Avatar
I think so...
Old 09-30-2006, 10:09 PM
fastergoat's Avatar
Or it could be the fact that the engine is sucking in massive amounts of air? Mine does the same thing it has also been questioned as a turbo.
Old 10-01-2006, 01:32 PM
k1200lt's Avatar
Originally Posted by GOGOGTO
I think so...
Clipped from another GTO forum:
Wind Rush Noise from Outside Rear View Mirrors (File Down Mirror Upper Mounting Boss and Hard Landing) #04-08-58-001 - (Jan 6, 2004)
2004 Pontiac GTO
Condition
Some customers may comment on a wind rush noise coming from one or both outside rear view mirrors.
Cause
This noise may be caused by an excessive gap between the mirror base and the window seal.
Correction
This condition can be corrected by filing down the mirror upper mounting boss and hard landing using the procedure listed below.
Determine whether wind noise emanates from the right hand or left hand side, and inspect for presence of gap between the mirror base and window seal. Proceed with repair below only if visual gap is present.
Remove the mirror from the door. Refer to the Mirror Replacement procedure in the Doors sub-section of the Service Manual (SI Document ID #1353519).
Cut the rubber seal back 1 mm (0.039 in) from the top of the upper screw mounting boss.
Notice
Do not remove too much material off the screw boss and hard landing otherwise the window operation (and seal) may be adversely affected.
File off 1 mm (0.039 in) from the upper screw mounting boss and hard landing.
Reinstall the mirror to the door.
Check that the window operates correctly.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
B4155 (Right Hand Side)
Mirror, Outside Rear View -- Replace
Use Published Labor Time
B4156 (Left Hand Side)
Add:
To File Mirror Upper Screw Mounting Boss and Hard Landing
0.1 hr
Quick Reply: My car whistles ?????
