Pontiac GTO 2004-2006 The Modern Goat
how to adjust throttle cable?
Old 11-29-2007, 12:05 PM
slackr's Avatar
Default how to adjust throttle cable?
i bought an aftermarket throttle body (80mm professional products) it has an adapter plate/spacer if using w/ the stock intake manifold. just about done but the throttle cable is a tad short (because of the adapter plate/spacer).
is there a way to adjust the throttle cable?
thanks.
i tried a search but the only results were from the ls1 camaros.
Old 11-29-2007, 12:52 PM
04blowngoat's Avatar
thanks.
Yes.
About 12" back on the cable itself from the throttle body, there is a throttle cable housing to adjust slack. Slide the lock clip on the housing open. move the housing to allow slack. Slide the lock clip back to the closed position.
Very easy.
Old 11-29-2007, 02:40 PM
slackr's Avatar
Originally Posted by 04blowngoat
Yes.
Very easy.
thanks.
Quick Reply: how to adjust throttle cable?
