Pontiac GTO 2004-2006 The Modern Goat
Blowing turn signal fuses
Old 07-07-2008, 10:25 PM
TIMBO0566's Avatar
Default Blowing turn signal fuses
I installed the skip shift eliminator on my 2004 gto & it kept blowing the turn signal fuse. So i thought I put it on the wrong connector. I went to my best info site LS1 tech & checked it out. Well I put it on the right connector, So then I disconnected it all together. Well I started the car up & it blew again. Does anyone know what it could be or should I just take it to the dealer?
Old 07-13-2008, 02:06 PM
mxmatt137's Avatar
I had a similar problem with my gto when I first got it. I took it to the dealer since it was a warranty part. Turns out, when I put the car in reverse it was popping the turn signal fuse. I had a broken switch of some sort.
You might want to take the panel under the steering column off and when you start the car, see if the fuse pops. Then put it in reverse and see. I noticed mine that way.
Old 07-13-2008, 06:58 PM
TIMBO0566's Avatar
I took it to the dealer it was my reverse switch on the transmission.
Quick Reply: Blowing turn signal fuses
