Pontiac GTO 2004-2006 The Modern Goat
will the stock 04 intake fit a 90mm TB
Old 08-01-2008, 04:48 PM
Punisher GTO's Avatar
Default will the stock 04 intake fit a 90mm TB
will the stock 04 intake fit on a 90mm tb?
Old 08-02-2008, 08:11 PM
batboy's Avatar
Nope. The 04 uses a 78mm TB and the bolt pattern is also different I think.
Old 08-03-2008, 11:36 PM
GGTTOO's Avatar
You are correct Badboy. It will not fit without an adapter. It is best jsut to port and polish the stock TB or I know BBK makes an 85MM with an adapter for the stock IM...go to http://www.neweraperformanceparts.com
