anyone use atf +4 for power steering??
I've used atf in p/s systems for my daily drivers with zero issues (currently in my jeep), but for a car going on track I would stick with normal ps fluid like redline that is proven to be effective. I'm not sure how much heat atf can handle vs. a quality ps fluid like redline. Just my 2 cents.
aft+4 worked PERFECT. again i have a turn one pump with oil running through factory cooler then a small cooler mounted behind the radiator. Ran 20 min sessions at road america with race slicks. outside temp 75-80 degrees.
I second using Redline D4 ATF. We can't get the power steering fluid from Redline up here easily so I figured I'd try it. Worked like a champ through 5 sessions that lasted 20 minutes each on a tight course.
I've got a Turn One pump as well.
