Crate LS3 + HPDE + sticky street tires, should I be concerned?
Just like the title says. I've spun a rod in my H/C LS1 and I am looking for a new engine. I *was* leaning towards a crate LS3 + pan baffle and just over filling the pan, but I've now read a good bit to make me concerned that the only way my engine would survive is a dry sump setup, which makes me lean towards just getting an LS2 short block, putting my heads on it, and getting a dry sump.
Someone enlighten me. I'm looking for an engine that would survive just fine doing 3-5 HPDE events per year on 275 wide sticky street tires.
Thanks!
Thanks!
If you have the cash, for sure an LS2 with the dry sump. It's no comparison.
I've heard lots of people say it's just a matter of luck, or you only hear of the bad stories online...but after losing 2 engines in less than a year all due to lack of oiling I'm personally sold on dry sumps.
Mostly I really just dont want to spin another rod bearing. I dont know that I can take it again!
When you say wide sticky tires, are you talking R888's or take-off slicks from a pro team? Have you looked on the Vette forum? There was at least one large thread about the oil pooling in the PS head when G's were over a certain point for a minimum time. Something like 1.2G's for more than 4s comes to mind.
My understanding is that the only solution (short of being less aggressive in your driving behavior) is a dry sump setup with the LS3 heads... overfill, baffle, accusump, lifter tray drain holes... all didn't help. Not sure if anyone's tried using external drain back lines with custom holes on the head.
dont know what Gs i pulled at any time, but i just used the improved racing baffle and 6qts of oil in my LS1, and sent an oil analysis every time i changed, which was once a season, and there was never any extra wear present that indicated loss of oil. and i ran used slicks every time, for years, at most 5 hpdes per season.
My car pulls up to 1.4 G's, using Hoosier R6's. I use a dedicated gated road racing pan, remote filter, oil cooler, and Accusump.
The data log shows that the oil pressure never drops below 30psi; and below 40psi only rarely.
A dry sump would be nice for racing, no doubt about that. But, do you need it? Probably not. Dry sump adds weight, cost, and complexity, with more leak and failure points.
Track use without an Accusump is just asking for trouble, IMO. They are inexpensive, simple, and easy to install. Why not?
What Bob said. I can get into my accusump reserve on an autoX course with a 7 qt baffled pan and a crank scraper, which is nowhere close to road course levels of G force. It's cheap insurance. Total oil capacity now, between filter/pan/lines/oil cooler/accusump is just a hair over 10 quarts.
Dry sump would greatly improve oil consumption and windage, but it isn't a necessity. Just be prepared to burn a little oil over a 20 minute hpde.
Improved Racing pan baffle for sure, while you're there add a crank scrapper. Other tricks include drilling the lifter trays half way down to reduce the amount of oil they hold, reduced orifice pushrods. Pm me for a discount code for Improved if you go that way, they sponsor me in the Optima Challenge this year.
