454 LSX balanced rotating assembly for Tall Deck block - Eagle, Wiseco, FM SOLD
Category: Accessories
Price: $1234567890
Location (State): AL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
similar set up from Texas Speed:
https://www.texas-speed.com/p-1029-t...-assembly.aspx
Includes:
Eagle 4.250" 4340 steel crank with ESP armor (nitride)coating
-crank has been balanced and has had a roll pin added for the ATI balancer hub, NO BALANCER (hub only) - balancer shell must be purchased from ATI (300.00), or you can run a different set up all together not using pin
Eagle H-beam 4340 steel rods 6.460" length, ARP 2000 7/16" bolts
Wiseco custom LS7 valve pocket flat top piston, -8cc's, with GFX 1.5MM, 1.5MM, 3.0MM rings, heavy wall tool steel pins, 1.165" CD
FM 152M Competition main bearing set
FM 8-7100CH Competition rod bearing set
Serious only,
