Machined and assembled LS6 for sale
Price: $5000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): TX
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Stock 3.622" crank. Main and rod journals turned, crank straightened and balanced within 1/2 oz.in.
Je pistons, 1.315" comp height, 2 cc valve relief, and piston to cylinder wall clearance at .0045"
Piston is .020" out of the hole
Cosmetic .060" gasket with 3.910 bore
Compression ratio is 11.5:1
Total Seal ring pack, top ring gap at .020", second ring gap at .024"
Eagle H-beam rods 6.125 rod length with ARP 2000 bolts
ARP main studs and head studs
Clevite H-series main bearings and Clevite A-series rod bearings
GM 243 heads, cnc ported and flowing 310 cfm @ .650" lift
Pac 1207x springs, scorpion 1.7 rocker arms, Comp 7.350" 3/8 push rods, and hyd roller lifters. 1.600" stainless steel exhaust valves w/ hardened tip and hard chrome plated stem 4.870" overall length. 2.055" stainless steel intake valves w/ hardened tip and hard chrome plated stem 4.910" overall length.
SLP double row timing set
Melling high volume oil pump
Bullet cam 237/241@.050" .3677"/.3677" lift and 111 LSA. ICL @ 110
Block was align honed to spec, cylinders honed to 3.905", and deck surfaced to allow piston .020" out of hole
Intake, throttle body, coil packs, wires, headers, and any other accessories not included but I will include a used 3k mile Spec stage 2 LS clutch and steel flywheel for free.
Will ship if cost is covered by buyer.
This was my build meant for my personal car. Now some things have changed and I have other priorities.
I have not dyno'd this engine and it comes as is. I do have an ARP 234-2503 crank bolt that is not shown that will be installed whenever I get to it. I also have full blueprint records and I will give them to any serious inquiries.
Please feel free to ask any questions.
