Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Half filled Iron 365" Longblock
Old 10-05-2015, 11:36 PM
slowlsx's Avatar
Default Half filled Iron 365" Longblock
Price: $8500
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): TX
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
brand new engine built by Hsquared racing here in Houston Texas. motor is Half Filled and can supply the complete invoice if needed. invoice was 12k asking $8500. any questions text 713-410-2880
would entertain a trade for a simple forged ROD/Piston 5.3-6.0 shortblock plus cash.
Align hone main bores to spec and to ensure correct bearing
crush
Torque Plate Hone Cylinders for correct piston to wall clearance Block True/Square decks to correct quench using customers
components on V8 - up to .025"
Final wash block, stress relieve, prep for assembly etc... Balance crankshaft to within .25oz/in.
Shortblock Assembly - Check Clearances, check piston deck
height, gap rings etc
GM 6.0 L Iron Engine Block - inspected and ready for machining Inspect and polish crankshaft
Callies Compstar 4340 Forged Nitrided Steel Racing Crankshaft 3.625" stroke 24x reluctor, std mains and rods
Compstar series H-beam connecting rod for LS1 6.125 length w/
2.100 rod journals
Wiseco Racing Pistons 4.005 bore, 1.110" CP HT, 15cc dish, dry
film coated skirts, 1.2mm, 1.2mm, 3.0mm ring grooves (K444X05
Wiseco .200 wall tool steel wrist pins for high power applications
Wiseco Performance GFX series piston rings for 4.005 bore size 1.2mm
nitrided steel top ring, 1.2mm iron napier second ring, 3.0mm std tension oil ring
ARP main stud kit for LSX series engines 234-5608
ACL 3/4 groove racing main bearings for LSX engines - Std H
series
ACL chamfered racing connecting rod bearings for 2.100" SBC
journals, Std H series
GM Performance LSA 6.2L cylinder head CNC Ported by West Coast Cylinder Heads.
REV Racing Inconel Exhaust Valves - inconel material for higher
heat applications - 1.600" head dia, 5.450" O.A.L., 5/16 stem dia
GM Performance Hollow Stem Intake Valves (per valve)
PAC valve spring kit for .660" max lift.
(comes with titanium retainers, hardened locaters, new seals &
valve locks)
Morel linkbar hydraulic roller lifters
H-Squared Racing Custom Grind Racing Camshaft
ARP 8mm 12pt Cam Bolts (for three bolt cams only) 134-1003
GM Factory rear cover gasket # 12639249
GM Factory Valley Cover Gasket for LS2 and later engines only!!!
12610141
Melling race high volume LSX oil pump (clearanced for double
roller)
7/16 dia double tapered x .165" wall
thickness & 3/8 dia straight x .135" wall
thickness
ARP 234-4313 CA625 Head Stud Kit
ARP aftermarket 12pt harmonics damper bolt with shouldered
washer 234-2503
GM oil diverter plug (barbell) for LSX # 12573460
GM Factory front oil galley expansion cup plug #94276
ATI super damper for LS1/2 Camaro OEM diameter without A/C
Old 10-08-2015, 09:51 AM
2KSS's Avatar
pm sent for damper
Quick Reply: Half filled Iron 365" Longblock
