Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
NEW 383 iron LS1, Wegner CNC 799 heads w/Ti valves, BTR Stg IV, Vicr Jr carb, Complet
Old 08-30-2015, 12:04 PM
helicoil's Avatar
Default NEW 383 iron LS1, Wegner CNC 799 heads w/Ti valves, BTR Stg IV, Vicr Jr carb, Complet
Price: $0
Location (State): MO
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Selling a brand NEW 383 LS1. Parts list as follows. Will be a solid 550-570 fwhp engine with a 750cfm carb. Great street effort.
-Iron Gen III 5.3L bored to 3.898" (Stock LS1 350/5.7L bore), these are well proven combos, done several with great results even in the 800HP range, torque plate honed, align honed mains w/ studs installed
-ARP Main Studs
-Lunati 4340 forged 4.0" stroke crankshaft (balanced), 58T reluctor (tig welded to crank)
-Crower 6.125" I-beam 4340 rods with ARP 2000 bolts
-Race-Tec (JE) forged dish pistons with 1.5MM, 1.5MM, 3.0MM ring pack, 10.9:1 comp ratio, -6cc dish volume
-Total Seal AP steel ring set, AP steel top, Napier second, low tenison 3.0mm oil
-Wegner CNC Nascar spec heads, 799 castings (same as 243), copper seats, Titanium intake and exhaust valves (std. size), have been ran before - but now are completely fresh. NEW BTR .660 spring kit with TI retainers, NEW TI valves - these heads will support 640HP NA strokers. 67cc chambers
-ARP head bolts
-Clevite Main bearings (MS2199H)
-FM competition rod bearings (8-7100CH)
-Durabond cam bearings
-BTR stage IV hydraulic roller cam, 235/242 .620/.593 111 lsa
-Morel drop in hydraulic roller lifters
-billet single roller JWIS timing set with torrington bearing
-Mellings HV10296 oil pump
-stock rockers w/ BTR trunion upgrade kit
-Comp Cams 7.400" .080" Hi Energy push rods
-Felpro MLS head gaskets
-Edelbrock Victor Jr. 4150 carb intake
-LS2 front cover
-LS2 valley cover
-rear cover
No oil pan, valve covers, carb, or ignition. Can run a MSD 6012 and stock coil set up for ignition.
All parts are Brand NEW unless noted otherwise.
Can crate and ship for 250-300 depending on location
Serious only,
Contact Tim
314-45two-66-three-nine
Call, text or PM
Old 09-01-2015, 10:52 PM
helicoil's Avatar
to the top
Old 09-03-2015, 04:03 PM
CWallen's Avatar
Are you interested in selling just the heads?
Old 09-03-2015, 10:19 PM
fiteboss's Avatar
That's a screaming deal. If it were 24X you would already be getting my money.
Old 09-25-2015, 10:22 PM
helicoil's Avatar
****sold***
Quick Reply: NEW 383 iron LS1, Wegner CNC 799 heads w/Ti valves, BTR Stg IV, Vicr Jr carb, Complet
