Garage sale - LS Swap parts, BRP brake swap, 4th gen brakes
Category: Accessories
Price: $123
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
64-72 Chevelle / Skylark / Cutlass, 67-69 Camaro, 68-74 Nova BRP Front disc brake conversion kit - Includes hubs, adapter plates, bearings. This kit is brand new from BRP, never installed on my car - This kit is for cars originally equipped with front drum brakes - SOLD
BRP F-body rear brake brackets. Fits "early 10 & 12 bolt rears" per BRP. - SOLD
64-67 Chevelle SBC frame stands. This is a set of OEM frame stands from a 66 Chevelle equipped with an SBC. Great for swapping an SBC or LS into your 64-67 A body - Parts in great shape - $60
4th gen f body OEM brake booster studs were removed for a different mounting application- $30
4th gen f body OEM master cylinder, reservoir, short lines - $25
4th gen f body disc brake backing plates Non traction control- SOLD
4th gen f body Used front brake calipers and brackets, cleaned up a bit and hit with high temp paint. One bracket has a stuck guide pin, you must either free it up or use as a core. $60
4th gen f body Used rear brake calipers and brackets, cleaned up a bit and hit with high temp paint. New Raybestos hardware. SOLD
CPP Adjustable brake proportioning valve - $25
Dorman H380483 rear soft brake lines 2 available - $7 each or $11 for both
Delphi F99 oem fuel pump. New. Purchased from racetronix, never used. $40
92-96 B-Body fuel tank, pump, sender, module. $100 (local pickup in 18013 only)
