Turbo 2007 NNBS Silverado RCSB
Year: 2007
Make: Chevrolet
Model: Silverado 1500
Price: $16000
Mileage: 110000
Location (State): Can-ON
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
http://www.performancetrucks.net/for...velope-527991/
I came across another project i am interested in,but would like to sell this first.
NOT PARTING OUT.
I am still working on the tune and will continue till finished.
Truck:
2007 Chevrolet Silverado 1500 NNBS Reg.Cab Short Box
Base truck with carpet,A/C,CD,PL and keyless entry,G80-3.23:1
Interior about 7/10
Autometer 2&5/8 liquid filled boost gauge,AFX/NGK/NTK Wideband,Turbosmart in-cabin boost controller
Body is scratched up and dented but no holes
Front Suspension;Belltech struts and spindles no front sway bar
Rear Suspension;Diff. flipped,Static kit,Calvert 9 way shocks,helper leaf and spacer block removed
Engine:
4.8 Rotating assm.not touched
Comp.Cam 214 int. 226 exh. .559".569" 115 lobe sep.,LS7 lifters,LS2 timing set/damper
Pro Comp head studs,GM MLS gaskets,fresh 243 heads resurfaced -.030",PAC 1208x valve springs with Ti retainers
-12 drain welded in pan,oil pump spring shimmed
Holley Hi-Ram,LS9/ZR1 Injectors and MAP(Caspers adpt. harness),Stainless/Teflon fuel line/crossover
Jaz catch can
Turbo Set-Up:
Trick stage 4 Stainless hot side,MP T76 turbo,Precision PW39 wastegate,DEI blanket,Stage 8 header bolts,Vibrant Stainless muffler/down spout
Procharger 4 core intercooler,Tial blow off valve,3" aluminum piping
Stainless/Teflon -4 and-10 feed and drain lines
Transmission:
Fully built 4L65E
Everything Sonnax has to offer including Billet Input/output shaft and drum,new 1st/2nd ratio gear set
Deep Hughes Pan
10" 3500 billet cover multi disc,lock-up converter
*this is a max level trans. and was a very costly build!!
Wheels:
Bogart D10
15x11.5" and 17x4.5"
295/65-15 MT Drag Radials and M&H 4.50x28-17"
Gorilla wheel lock system
The majority of the parts were new for this build!
4300lbs
Idle vid:
http://vid148.photobucket.com/albums...psxg9ik0xt.mp4
Would be willing to meet on the U.S. side,northern NY
[QUOTE=jbeane;19034894]99 hugger orange z28
LY6 6ltr ls3 top end
cam, LT's etc etc.
stg3 4L60
12bolt, bmr, qa1's, NX, weld's
new interior, fresh paint, vfn, tsp
lots and lots more. can go into deeper details if any interest.
car makes 426whp/401tq NA and 500whp/500tq on 100 shot, with the converter unlocked.
Nice Car-No thanks
Dom
cam, LT's etc etc.
stg3 4L60
Nice Car-No thanks
Dom
