01 Z28 TH400 Strange S60 +more
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $7000
Mileage: 200
Location (State): MI
Color: Beige
LS Engine?: Car has LS engine
01 Z28 200k body cleanest car I have seen dont let miles scare you, no rust anywhere car came from texas
M6 car now has auto pedals
Strange S60 4.10 gears no abs 1000miles
Strange Rear drag brakes (on car)
New Dennys Nitrous Ready Driveshaft with 1350 ujoints $700
Spohn lower control arms, believe I have a couple other sets will give also
Spohn Rear Anti-roll bar (not installed)
umi adjustible torque arm crossmember mounted w/ ds loop
Rear 3-way adj comp shocks new in box
rear Air Lift drag bags
TH400 w/brake less than 1k miles
Bought off of tech member ddr698
Trans has ultra bell and tail shaft
I cant find info I had on trans but it was built to handle atleast 1200hp
has a deep pan with 2 bungs welded into it one for temp gauge and one for drain
B&M trans cooler mounted "dope style" with braided telfon hose
Hughs SFI flexplate ARP bolts
Yank 4000 stall
Hurst Pistol Grip Quarter Stick shifter
AJE Tube K member with manual rack (not installed bare metal)
Spohn upper and lower control arms (used not installed)
Car currently has prostars on it 15x10 in rear with new 295 m/t drag radials and 3.5 up front
Also have another set of wheels with damn near new 275 bfg kdw i believe
Have an OEM SS Spoiler Red in color (300)
Aftermarket SS hood has custom paint so needs painted
Manual Brakes with line lock braided flex lines
Motor:
Right now motor is basically stock has factory manifolds and gutted cats
Ls6 intake aftermarket lid
I have everything for a cam swap T-REX cam has 500miles on it pushrods, gaskets
1 3/4 stainless headers forgot brand but they are not cheap ebay ones (not installed) think I have gaskets also
nitrous plate set up never been on car (not installed)
extra set of coils
I am sure I am forgetting a few things but I am getting out of the 4th gen stuff so I will give who ever buys the car everything I have.
Car runs and drives the converter is obviously big for car but I never got to the motor. If you put cam in car converter will be perfact for the set up
There is an issue with brakes I believe there is air still in them car stops but not all that good, but it is manual brakes
Car now has a bowtie slp grille however this grille will also go with car
Any questions feel free to ask
Thanks,
Bill
734 306 9290
