Carb'd LS swap parts
Category: Accessories
Price: $1250
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): VA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Holley 650 Double Pumper in "hardcore gray" with electric choke and throttle position sensor already installed (needed with the FAST EZ TCU box). Carb goes for $612.95 new from Summit racing without the TPS. PRICE - $450
Mallory Series 110 electric fuel pump. The aluminum body has some surface corrosion but it runs great. New from Summit Racing is $300.95. PRICE - $100
Holley fuel pressure regulator with mounting bracket and pressure gauge. New from Summit is $97.34. PRICE - $50
MSD 6010 ignition box for LS motors with 24X reluctor crank. Wiring harness is 100% in-tact as is the cable to connect the box to your computer. The tune currently on the box was set up for a 6.0L running the above fuel system. Factory instruction manual included. New from Summit $356.95. PRICE - $250
FAST EZ TCU for 4L60/65/70 transmissions. Wiring harness is 100% in-tact, as is the power cable for the hand held programmer and the cord to connect the programmer to the ECU. Factory instruction manual included. New from Summit $611.97. PRICE - $450
Autometer Cobalt 2 1/16 wideband air/fuel ratio gauge. Can be programmed for various ratios and can also be used for data logging. The was very useful when tuning the carb'd LS set up. New from Autometer $309.95. PRICE - $200
New, unopened, set of MSD "cut-to-fit" LS spark plug wires. New from Summit for $149.95. PRICE - $125
