2001 Trans Am WS6 SOM built
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $20500
Mileage: 91887
Location (State): IL
Color: Orange
Transmission: Manual
Drivetrain: Rear Wheel Drive
right now has a messed up output shaft on the trans which will be fixed soon or you can buy as is for the current price. obviously will go up a bit when fixed. car runs fine now just has a vibration at higher speeds.
Engine: LQ4 shortblock, TSP ported oil pump, LS2 timing chain, 62cc PRC Stage 2.5 LS6 heads, PRC duals, 10.55:1 compression, PatG/EPS 238/242, .604/.605 112+4 cam, LS7 lifters, MTI clear lid, LS6 intake, Shaner S3 TB, Warlboro 255 with Hotwire kit, SVO greentop 42lb injectors, Pacesetter LTs, TSP Catted Y, Magnaflow, e-cutout contorlable from driver side in car, Monster Level 3 clutch
Car was tuned at straightline performance and put down 444rwhp and 438rwtq
Rear End: strange 9", 4.10s, 31 spline axles, chromoly 1000hp driveshaft
Suspension and Wheels: qa1's all around, 2013 grand sport rep wheels with nitto tires,UMI frame ties, trans brace, crossmember, and tunnel brace/loop
car also has an aftermarket head unit (nice touchscreen double din) and a little sub woofer
message me here, email me or text me if you have any questions. email and text will likely get a faster response. price is a bit flexible but don't think ill just give it away.
Email: dillonroth1@gmail.com
Phone: 847-414-0115
car is in the south suburbs of chicago
