Price: $2400
Location (State): OH
Item Condition: Brand New
LS Engine?: Fits LS Engine
have a 2000 GM 5.3L motor for sale. Big crane cam, 243 cylinder heads, everything else stock but new everything. All new gaskets and rod and head bolts. All new cam, rod and main bearings(standard size measured in specs.) Everything was sent to machine shop where he cleaned in wash tank. Cleaned and polished crank(measured in spec) New timing chain. Front and rear covers are new. And all new seals. Exhaust and intake Manifolds are not on engine but I do have, with the gaskets. Depending on what you want to do, you may not use either of them, but they will be included. I HAVE EVERYTHING DOCUMENTED, PARTS RECEIPTS AND MACHINE WORK. I'm only asking 2400 which covers parts cost. I'm not including my labor in price. Will show you all receipts if you would like to see. The cam is from crane cams and that came with 7.400 push tubes. Engine was assembled per manufacturers procedures, along with all torque specs of bolts. Do also have a set of BOSCH 440cc injectors EVI, sold separate at 150. And a auto trans flex plate ATP Z-270 at 48.44 I have everything for the engine, fuel rails. harness, etc. if you want them great, if not no big deal. Thanks, Scott call or text for more information
