Fuelab 41402-2 in-line Fuel pump rated for 1300Hp
Category: Accessories
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): OH
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
***Specs from FUELAB***
140 GPH @ 45 PSI - RATED UP TO 1300HP Increase performance capabilities with extra flow for higher powered engines.
41402 Prodigy Fuel Pump High Efficiency EFI In-Line
Item-details
Pump Features
Compatible with gasoline, diesel, methanol, and ethanol
High efficiency sling vane positive displacement pump
Special housing shape for extremely quiet operation and steady pressure
Carbon 9-vane construction with pressure balanced rotor for high reliability
Backed by a 2-year limited warranty
Motor Features
Lightweight super-efficient dc brushless motor reduces current draw
Low mass rotor for high speed reaction to changes in speed and flow
Powerful high flux density Neodymium rare earth magnets
No motor brushes to wear out or corrode (low-Sulfur diesel, no problem)
Wet motor design, no dynamic shaft seals that can wear out
Electronic Features
Internal speed controller for variable flow operation
12 to 16 volt vehicle electrical system compatibility
Accepts PWM input for speed control
No expensive add-on voltage regulators or pump controllers required!
Continuous duty–motor speed can be adjusted for street or strip fuel demand
Construction Features
Compact, lightweight design, less than 3 lbs, overall length 6.9", diameter 2.63"
Billet Aluminum Construction with anodize per MIL-A-8625, Type II
High quality mounting brackets included
Long-life, multi-fuel compatible Fluorosilicone static seals
Accepts standard or port style –10AN fittings
