Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Fresh 355 LT1 Shortblock & Moser 12 bolt
Old Jan 7, 2012 | 01:41 PM
ddr698's Avatar
Default Fresh 355 LT1 Shortblock & Moser 12 bolt
Category: Racing Parts
Price: $1500
Location (State): NE
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Fits LS Engine
EVERYTHING IN THIS THREAD IS NOW SOLD SOLD SOLD.
I have up for sale a 355 LT1 with forged pistons and rods. This was professionally assembled and has never been fired (heads have been bolted on to mock up the assembly but the motor has never been installed or started). Motor is in perfect condition and includes a factory turned/polished crank, forged SCAT I beam rods, and Forged TRW -5cc flattop pistons (part number is pictured in one of the pics below). Perfect replacement for a blown engine or a great performance upgrade for someone wanting to spray.
SOLD
Moser 12 bolt rearend with Eaton posi, 4.11 gears, very hard to find 4 channel LT1 ABS, 1350 yoke, Moser Aluminum rear stud girdle, 30 spline axles, bolt in axles (no c clips), 4 channel 53 tooth reluctors for 93-97 traction control abs, Powdercoated gloss black (tho it is scratched from being installed/removed and handled). Has about 8k on it since new. Excellent condition. As optioned this was a $3050 Rearend!! Plus im including factory lt1 brake setup painted red, with cross drilled rotors $$$SOLD$$$
A few notes - This can be installed on an LS1 if you switch the backing plates. (If you wish to retain abs on an LS1 you will need to swap over your 47 tooth reluctors onto the axles.) Or im including the complete brake setup and you can just use the LT1 setup as there is no performance difference between the two anyway.
ABS on LT1 cars - if you don't have traction control this rearend will disable your ABS.
Old Jan 7, 2012 | 04:00 PM
AP30thZ's Avatar
Is the rearend $2250 shipped or unshipped?
Old Jan 7, 2012 | 04:55 PM
ddr698's Avatar
PM sent your way.
Old Jan 11, 2012 | 09:41 PM
ddr698's Avatar
Up top!
Rearend works with any 93-02 f-body, just not all will retain stock brakes/abs.
Old Jan 12, 2012 | 03:02 PM
BigBadWhitey's Avatar
What are the chances the 355 will hold up to boost?
Old Jan 12, 2012 | 05:35 PM
ddr698's Avatar
It would probably hold up to a decent amount of boost but really youd probably want a negative dished piston unless you are running an aftermarket heads with a larger combustion chamber like 64cc or 72cc.
Old Jan 18, 2012 | 07:55 PM
ddr698's Avatar
Up top! Lowered price on rearend!
Old Jan 23, 2012 | 04:14 PM
ddr698's Avatar
Bump up!
Old Jan 26, 2012 | 06:57 PM
ddr698's Avatar
Up top!
Old Jan 28, 2012 | 07:51 PM
ddr698's Avatar
Up top!
Old Jan 30, 2012 | 06:57 PM
ddr698's Avatar
Up top!
Old Jan 31, 2012 | 07:15 PM
ddr698's Avatar
Bump!
Old Feb 7, 2012 | 09:55 PM
95sscamaro's Avatar
What is your best price shipped on the rearend to 32771
Old Feb 7, 2012 | 10:17 PM
ddr698's Avatar
Sorry the rearend sold..... Shortblock still available.
Old Feb 9, 2012 | 10:22 AM
ddr698's Avatar
Up top for the shortblock
Old Feb 12, 2012 | 05:04 PM
greg58's Avatar
Hello, what cam is in the shortblock? Stock F-body?
Thanks Greg
Old Feb 12, 2012 | 06:07 PM
ddr698's Avatar
There is no cam in it. Its a block with rotating assembly in it, no valvetrain (as pictured).
