Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Moser 9", PST, Faceplated T-56,roller rockers, Z06 wheels
Old Jan 22, 2012 | 04:03 PM
DAVESS02's Avatar
Default Moser 9", PST, Faceplated T-56,roller rockers, Z06 wheels
Category: Drivetrain
Price: $2500
Location (State): IL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Moser 9" with Alum. Moser bolt through case, 35 spline axles, detroit locker, 4ch ABS, 3:70 gears with backing plates. Also has relocation brackets and standard type swaybar mounts welded on. Ready to bolt in. Has about 15K of daily driven use behind a mild cam'd 403. gears make a little noise, nothing bad.
$2500
T-56 from 02 F-body. Six Speeds faceplate conversion 1st-4th, synchro'd 5,6,Reverse, assembled by me. Had all bearings replaced when built. 30 spline Viper output conversion. No shifter. I've got another thread with detailed pics here:
https://ls1tech.com/forums/manual-tr...l#post15981074
$2100 I go through it, bead blast the case, replace anything as needed
I've begun the rebuild and I'm replacing the 5/6 cluster as the splines are worn and 5/6th slider assembly since they got beat up. The face plates are in good shape and are gonna be de-bur'd before re-assebly. Will be another 2 weeks before its done
PST 3 1/2" driveshaft. Measures 41.5" between center of u-joints. Purchased new from Bob @ Exotic after I got the 9" installed Spicer yoke $415
UMI chromoly torque arm. tunnel brace style with DS loop. Modified to work with my 3" true duals. $415
04 Z06 wheels. Painted a cleaner silver then factory. Have both camaro and corvette center caps plus a pint+ of extra paint. Have some small scratches around the center hub from the tire mounter. Fronts have 17" Kumo's with lots of tread left. Rears have bald/worthless 305 35 18 ET Street II's No curb rash whatsoever. SOLD!
Eclipse CD7200mkII copper plated chassis, time alignment and 7 band PEQ. Top of the line eclipse single din deck. These units are RCA output only, NOT INTERNALLY AMPLIFIED. You MUST use with an amp. has a bit of wear on the lettering on the detachable face. Comes with wire harness and case for face storage. $325
Comp Cams Magnum 1.75 steel roller rockers, studs, and guide plates. 15K on these. For cathedral port(non offset) heads.
$350
All items are available for local pickup. Shipping at buyers expense.
Old Jan 22, 2012 | 10:59 PM
1998MysticZ28's Avatar
shipped price to 33467
Old Jan 25, 2012 | 06:38 PM
Zmg00camaross's Avatar
So the trans otherwise is in good shape? I will see what tax time has to offer and maybe just maybe we can work out a deal.
Old Jan 26, 2012 | 09:56 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
God I want the wheels.
Any use for a full set of body armor or an Ibanez guitar autographed by Mudvayne (All 4 members)?
Old Jan 26, 2012 | 10:21 PM
SF 1HOTLS1's Avatar
if you decide to lower the price on that moser i'll take it for the right numbers.
Old Jan 27, 2012 | 07:38 AM
DAVESS02's Avatar
As cool as that sounds, I need cash for more wheels.
Old Jan 28, 2012 | 09:37 PM
00Wildcat's Avatar
I'm interested i the third member if you will seperate.
Old Jan 30, 2012 | 12:29 AM
whitemike03911's Avatar
If you sell the 3rd member I'm interested in the housing.
Old Feb 1, 2012 | 08:05 PM
DAVESS02's Avatar
Thanks, but not looking to part out.
Old Feb 1, 2012 | 11:04 PM
hotjohnnyls1's Avatar
lowest price shipped on the z06s to 94579?
Old Feb 12, 2012 | 03:18 PM
Bruser's LS1's Avatar
how much for the trans shipped to 75043? Are you sure that s the only internal issue?
Old Feb 13, 2012 | 11:06 PM
DAVESS02's Avatar
PM sent. Gonna go ahead and freshen up the trans before sale.
Old Feb 14, 2012 | 04:28 AM
superman2002's Avatar
Send pics of trans and rearend to 6203049031 plz
Old Feb 15, 2012 | 01:40 PM
would you take 2000 for the rearend or 1200 for the tranny
Old Feb 16, 2012 | 07:28 AM
DAVESS02's Avatar
Not a chance.
Old Feb 17, 2012 | 09:18 PM
94Ztwentylate's Avatar
still got the wheels?pm a shipping price to texas 76180.il pay the shipping if its not completely outragous
Old Feb 20, 2012 | 04:50 PM
gmoney1082's Avatar
Pm sent
Old Feb 22, 2012 | 11:41 PM
DAVESS02's Avatar
Wheels sold to 94Z, THANKS!
Old Feb 22, 2012 | 11:54 PM
Raptor_WS6's Avatar
how much for the rear shipped to 91345 business address
Old Feb 26, 2012 | 10:56 AM
DAVESS02's Avatar
To The Top!
