Hilton's Garage clean out! Some stuff left
Category: Drivetrain
Price: $12345678
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): LA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
$45
Low mileage front and rear Z51 shocks off 99 Corvette
$100 plus actual shipping
C5 Corvette 12 Disk cd changer
It's still in the car and works great.
$120 shipped
Stock 1998 camshaft
Slightly more lift and longer duration than a newer LS1 camshafts.
$50
4" Spintech muffler
Off a Mufflex exhaust. $50
F-body front calipers fresh from the bead blaster
With the pieces that came out of them as well as the brackets
$60
Camaro Upper radiator hose
part number 22352
$15
GTO power steering cooler
$20
Pilot Bearing, <6000 miles
$5
"Short belt" for an F-body with a stock pulley.
$12
Lifters off the 01 Z28
With trays
$55
Another set of trays
No clue where these came from. I think my parts must be breeding.
$15
Pushrods from the 01 Z28
$20
The timing chain in just about every picture $10
Not sure what it's off. Either a 2000 SS, 2004 GTO or a 2005 2500HD. There are 50K miles max on it.
1 Knock sensor
$12
Front cover
$30
Valley cover (I have two of these)
$25 each
Transmission mount off a 2004 GTO
$30
End links
$10
Duralast Gold front brake pads for 2002 Ford Explorer
They have a TON of meat left on them. Guy wanted them changed, who am I to argue?
$15
Transmission bushings
01 Z28 on left
04 GTO on right
$20 each
Oil pump off a 2005 2500 HD
$20
AC line off 2004 GTO
$20
Hurst "T" shifter
Fits Hurst Billet Plus shifter, who knows what else?
$20
Centerline center caps. Not sure whether the set is mismatched accidentally, intentionally, or came that way. I think it's pretty cool though.
$20
4" to 3" reducer. I'd planned to weld this to the Flowmaster 3x3" into 4" Y collector I had on the Camaro, but ended up running a 4" Mufflex over the axle.
$20
AIR off several cars.
EGR off 2000 Camaro SS
I made these thumbnails
$60 each set. (Sorry Mother Earth)
Stock valve springs, seats, and retainers.
MOST of the keepers (31/32)
MOST of the seals (13/16) 3 were ruined when I pulled them.
I'm a little compulsive and it KILLS me that these are incomplete!
I found this in a box with some car parts. I can't remember the last time we had a keg party. (That may be bad)
$20
Rockers sold.
Thanks Michael!
Fuel rail off a 01 z28.
Sold! Thanks Justin!
Red Strut Tower Brace
Sold. Thanks Steve!
New Weld center caps
Sold. Thanks Roger!
New 4" 90° chrome bend.
Sold. Thanks Sean!
NGK TR6 spark plugs
Sold! Thanks Kenny.
Rear Corvette O2 sensors
Sold! Thanks Sean
Alternator "overdrive" pulley
Sold! Thanks James!
Stock LS1 balancer, 2001 Z28
Sold! Thanks Andrew!
Valve covers
Sold!
Stock "unsmooth" baffles off an F-Body.
Sold! Thanks Mike.
Rear cover Sold! Thanks Denton!
Ram Powergrip HD Sold! Thanks Mike!
Stock length wheel studs! Thanks Dan!
Two cam retainers.
Sold! Thanks Denton and Brian
I'll continue to update this thread as things are sold, as well as when I find more things that I need to sell.
are the AIR sets $60 shipped? if so i might be needing one set. Failed my visual for emissions. Didnt even think to check for the Air injection setup but most of it was scrapped when my twins went on. I'll need to speak to my tuner to see if he has one i can just borrow but if not I may be hitting you up for a set.
