Nitrous built 347ci Long block and Nitrous Kit
Price: $6500
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): IL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, Small Block
LS Engine?: Fits LS Engine
Up for sale is a 347ci Long block that was built to handle a lot of nitrous This motor has less than 3K miles on it. I will not be parting the heads or the TB or the Intake. I will take a chance and try to sell this motor along with the nitrous kit as a package. If I get a good enough offer I might split up the kit and the long block. Everything is still in the car and this is a local sale for now. You will have to come and get everything once it is out of the car. I don't want to ship anything and if you are serious and want come out look at the stuff and hear the car idle you are more than welcome. This setup has gone 9.4 in the 1/4 and is capable of going even faster. I have a video of the pass if you want to see it please PM me. The car never got a chance to go another run due to being kicked off the track. I will also take a non refundable deposit from someone if they want to purchase this setup and hold it for 30 days. Once not paid in full in 30 days of taking deposit, I will not refund any deposits back and post the motor and or nitrous kit back up for sale. The deposit amount will very depending on the time frame and also on what price the parts sell for. I'm also willing to give someone the option on making a payment plan for this stuff if someone needs it. However I will be keeping parts here until it is completely paid in full. 2-3 month plan can be arranged with of course a slight increase in price of the parts.
Here are the details on the Motor and Nitrous Kit. I can take any pictures you want or videos of the car. The motor currently is with sits with regular plugs and needs +4 or +5 step colder plugs when on the trigger.
The only thing that will not come with the motor is the Oil Pan
347ci LONG BLOCK
General motors 5.7L block honed to 3.906"
General motors polished 3.622" crankshaft
Diamond 3.905" flat top pistons w/ -2cc valve reliefs
Eagle 6.125” rods w/ ARP 2000 rod bolts
Federal mogul 152M main caps
General motors cam bearings & cleveite rod bearings
Total Seal file to fit moly rings
PBJ adjustable timing set
SLP blackwing cold air intake
Custom ported LS2 90mm throttle-body
Trick Flow 215cc cylinder heads milled .035" to 58cc's
Trick flow 7.50 chromoly hardened pushrods
Cometic MLS 3.945 bore .065" head gaskets
ARP 2000 head studs
GM LS2 hardened timing chain
Harlan Sharp 1.7 roller rockers
PBJ 230/242 .613/.613 113+2 hydraulic camshaft
ASP under-drive crank pulley
SVO "red top" 30lb fuel injectors
NITROUS KIT
Nitrous Outlet custom made 1 gallon standalone w/ Aeromotive regulator
Nitrous Outlet 90mm plate system
Custom ported Fast 90mm LSX intake with PBJ & JMB custom plumbed directport system w/ NX shark nozzles
Nitrous Outlet Pro-Flow dual 15lb nitrous bottles
HSW custom smoke fuel & nitrous lines
HSW custom black braided line and fittings
Custom Nitrous Outlet switch panel
DynoTune TPS/Window switch/Dual stage controller
Price for Everything Listed, taken out and put on pallet for you to pick up is $8500.00
PM me or Text me at 773 Three One Zero 4240
Enite NITROUS KIT AND LONG BLOCK for $6500 OBO
This is a killer deal, my new motor is done and all my other parts are ready to be put on the car.
The current setup that is up for sale made over 740RWHP on a 250 shot. With 350 it ran a 9.4 with 1.44 60ft. This is a killer setup up for a great price for someone that is looking to do a nitrous set up
I will also part the entire setup up
1. short block (minus oil pan) $3500 obo
2. Trick Flow Heads $1800 obo
3. Entire nitrous set up including TB, FAST INTAKE, stand alone and injectors $1800 firm
