Fuel Pressure Regulator only reading 45psi but rail pressure is 58?
Old 10-21-2016, 11:26 AM
zblee's Avatar
Default Fuel Pressure Regulator only reading 45psi but rail pressure is 58?
Just installed an external fuel pressure regulator into my return line. I have 03 silverado which comes with return style and has the stock FPR in the fuel rail. I got a bypass plug so i removed the stock FPR and replaced it with the plug. then i plumbed in the FPR into the return line and put stuck a pressure gauge directly on the FPR . At the same time I have a gauge connected to the rail fitting to monitor the rail pressure. Since I bypassed the stock FPR i would think that the rail pressure would be the same as what is displayed on the regulator? maybe the new gauge I just got that is on the regulator is bad? any ideas? the gauge that i have connected to my rail picked up about 55 with the stock regulator a few months ago so i know that was working at that time ...
this is with the truck running , you can see its about 45psi ( i did not get gauge that was on the rail but it was showing 58 )
what do you think?
_Zblee
Old 10-21-2016, 12:17 PM
zblee's Avatar
unplugged the vacuum line and the pressure on the regulator went up. adjusted it to 58psi on the regulator and plugged the vacuum back in . rail pressure at idle is around 58~60psi now so i think i answered my own question and should be good to go!
_Zblee
Old 10-21-2016, 11:25 PM
truckdoug's Avatar
another thing to keep in mind too is as those analog gauges heat soak, they read lower psi.
Quick Reply: Fuel Pressure Regulator only reading 45psi but rail pressure is 58?
