LT1/LT4 and LS1/LS6 F-Body Part Numbers
Old 06-15-2005, 12:58 AM
ACW
ACW's Avatar
Default LT1/LT4 and LS1/LS6 F-Body Parts
GM Parts Numbers
There's more part numbers still left to be added to this from my list of ones that have been previously requested, but I wanted to go ahead and get it posted.
This will never be a complete list of part numbers - there are far too many of them - but the ones that have been asked for / posted already are the ones most likely to be looked for again.
Requests for part numbers can be posted in https://ls1tech.com/forums/new-ls1-owners-newbie-tech/336996-request-part-numbers.html , and they will be added to this list after being answered.
LH (Left-hand side) = driver side
RH (Right-hand side) = passenger side
Sources:
- GM parts manuals
- various posts on www.ls1tech.com and www.ls1.com
- http://beta.ls1howto.com/index.php?category=4
- http://shbox.com/1/Parts.htm
- http://www.1le.net/docs/1le_specific_parts.html
- http://www.30th-ta.org/30part.html
- http://www.collectorfbody.com/partnumbers.htm
- http://tech.firebirdv6.com/
Sections:
Audio, Battery/Alternator, PCM
Windows/Doors/Mirrors
Body
Brakes
Convertible
Emblems/Badges
Tail Filler Panels
Stripes
L36 3800 V6 Engine
Camshafts
Cylinder Heads
Valvetrain
Pistons/Internals and Crankshaft
Cooling
Ignition
Fuel
Intake/Throttle
Engine Oil
Exhaust
Lights
Power Steering and Horn
HVAC (Air Conditioning)
Seating and Upholstery
Controls and Interior Trim
Security
Suspension
1LE Suspension
Transmission
Rear Axle
Wheels
Documentation
ACW is offline
LAX008 (07-11-2023)
Old 06-15-2005, 12:59 AM
ACW
ACW's Avatar
Default Audio, Battery/Alternator, PCM
Camaro fixed antenna mast = 10425536
replacement black mast for power antenna = 10256439
Firebird power antenna (93-96, some 1997s) = 10269280
Firebird power antenna (98-02, some 1997s) = 10402860
Chevy version of power antenna (for Camaro retrofit) = 10402859
radio delete plate from a mid-90s Impala (fits 93-02 F-body) = 10197485
Camaro amplifier, low frequency audio (97 coupe - UZ7 premium audio) = ? (f. 16218051)
Camaro amplifier, low frequency audio (98-02 coupe - UZ7 premium audio) = 16257161
Camaro door front speakers (97-99 coupe - U62 standard audio), RH = 9361919
Camaro door front speakers (97-99 coupe - U62 standard audio), LH = 9361929
Camaro door front speakers (97-02 coupe - UQ0 standard audio), RH = 9361839
Camaro door front speakers (97-02 coupe - UQ0 standard audio), LH = 9361849
Camaro door front speakers (97-02 coupe - UZ7 premium audio), RH = 9361859
Camaro door front speakers (97-02 coupe - UZ7 premium audio), LH = 9361869
Camaro rear quarter trim panel speaker (97-02 coupe - UZ7 premium audio) = 16217731
Camaro rear sail panel (B-pillar) speaker (97-02 coupe - UQ0 standard audio) = 16193541
Camaro rear sail panel speaker (97-02 coupe - UZ7 premium audio) = 10447249 (f. 16235651)
Camaro door front speakers (99-02 convertible - U59 premium audio), RH = 9361859
Camaro door front speakers (99-02 convertible - U59 premium audio), LH = 9361869
Camaro rear quarter trim panel speaker (99-02 convertible - U59 premium audio) = 16257961
Camaro rear quarter trim panel speaker (94-96 convertible - U62 standard audio) = 16215431
Camaro rear quarter trim panel speaker (97-99 convertible - U62 standard audio) = 16220771
Pontiac door front speakers (99-02 convertible - X20 premium audio), RH = 9361879
Pontiac door front speakers (99-02 convertible - X20 premium audio), LH = 9361889
Pontiac rear quarter trim panel speaker (99-02 convertible - X20 premium audio) = 16257961
rear sail panel speaker bolt (m4.2x1.41x20, 12.5 od) (97-02) = 11516715
rear sail panel speaker nut (u-shaped, m4.2x1.41, 17 long, 13 wide) (97-02) = 11513715
rear seat Monsoon speaker cover, RH = 16671270
rear seat Monsoon speaker cover, LH = 16671271
12-disc CD changer (97-98) = discontinued, use 99-02 (formerly 16199553)
12-disc CD changer (99-02) = 25678544
12-disc CD changer cartridge (97-02) (Pioneer #JDT-1212) = 25678545
12-disc CD changer kit (changer and cartridge) = 12371528
wiring harness for 12-disc CD changer (97-02) = 12344003
Bracket 1 for 12-disc CD changer (98-02 Firebird and Camaro) = 10274252
Bracket 2 and 3 for 12-disc CD changer (98-02 Firebird) (need two) = 10276577
Bracket 2 for 12-disc CD changer (98-02 Camaro) = 10274254
Bracket 3 for 12-disc CD changer (98-02 Camaro) = 10276577
positive battery cable (98-02 V8) (AC-Delco #4SX53-2) = 12157131
positive battery cable (93-97 V8) (AC-Delco #4SX45-2T) = 12157373
positive battery cable (98-02 V6) (AC-Delco #2SX64-2F) = 15321052
positive battery cable (95-97 V6) (AC-Delco #2SX67-2) = 12157081
positive battery cable (93-95 V6) (AC-Delco #4SX39-2H) = 12157166
negative battery cable (93-02 V8 and 93-95 V6) (AC-Delco #4XX39-1C) = 12157374
negative battery cable (95-02 V6) (AC-Delco #2SX33A) = 12157153
battery tray and coolant recovery reservoir (93-02) = 10402687
battery tray and coolant recovery reservoir bolt onto frame (93-02) = 11514478
battery hold-down retainer = 14005061
battery hold-down retainer bolt = 11515984
LS1 alternator rear bracket bolt (98-02) (hfh, m10x1.5x35, 32 thd, 22.3 od) (1) = 11515767
LS1 alternator rear bracket bolt (98-02) (hfh, m8x1.25x50, 27 thd, 17.6 od) (1) = 11509666
LS1 alternator to bracket bolt (98-02) (hfh, m10x1.5x125, 25 thd, 22.3 od) (2) = 11516366
LS1 alternator front bracket bolt (98-02) (hfh, m10x1.5x90, 22.3od, dim A30) (1) = 11516360
LS1 PCM bracket (98) = 10284308
LS1 PCM bracket (99-02) = 10275815
LS1 PCM bracket bolt (98-02) (hfw, m8x1x25, 17 od, 6202M stl) = 11516413
ACW is offline
Old 06-15-2005, 01:06 AM
ACW
ACW's Avatar
Default Windows/Doors/Mirrors
F-body t-tops ('lift-off panels') (93-02), RH = 10313014 (formerly 10429585)
F-body t-tops ('lift-off panels') (93-02), LH = 10313015 (formerly 10429586)
t-top holder (for trunk area), RH = 10435202
t-top holder (for trunk area), LH = 10435203
weatherstrip conditioning (Dielectric Silicone Grease) = 12345579
power window motor (93-02) = 88960088
front side window stabilizer (need 2 per door) (held on with 10mm bolt) (93-02) = 10257988
window lift channel (93-02) = 16625875
window wedge (93-02) = 10198247
window outer sealing strip (93-02), RH = 10284222
window outer sealing strip (93-02), LH = 10284223
Camaro power window switch (94-96), RH = 10402837
Camaro power window switch (2 switches in one unit) (94-96), LH = 10402838
Camaro power window switch (97-02), RH = 10402841
Camaro power window switch (2 switches in one unit) (97-02), LH = 10402842
Firebird power window switch, RH = 10402844
Firebird power window switch (2 switches in one unit) (93-02), LH = 10402845
power window regulator (93-02), RH = 10305685
power window regulator (93-02), LH = 10305686
front side door lower hinge (93-02), RH = 16628998
front side door lower hinge (93-02), LH = 16631043
front side door upper hinge (93-02), RH = 16630874
front side door upper hinge (93-02), LH = 16630875 (93-94 was formerly 16626519)
Camaro door (inner and outer panels) (93-02), RH = 10274371
Camaro door (inner and outer panels) (93-02), LH = 10274372
Firebird door (inner and outer panels) (93-02), RH = 10274373
Firebird door (inner and outer panels) (93-02), LH = 10274374
windshield wiper arm (93-97), LH = 22155458
windshield wiper arm (93-97), RH = 22155459
windshield wiper arm (98-02), LH = 22154388
windshield wiper arm (98-02), RH = 22154389
windshield washer reservoir (93-02) = 22111377
wiring connector for wiper motor = 12129126
Firebird blue-tinted mirror glass (93-98 and early 99, with RPO DG7), RH = 10279515
Firebird blue-tinted mirror glass (93-98 and early 99, with RPO DG7), LH = 10279516
Firebird all-remote mirror (93-98 and early 99, with RPO DG7) (with tint), RH = 10279435
Firebird all-remote mirror (93-98 and early 99, with RPO DG7) (with tint), LH = 10279436
Firebird all-remote mirror (00-02 and later 99, with RPO DG7), RH = 10428121
Firebird all-remote mirror (00-02 and later 99, with RPO DG7), LH = 10428122
Firebird half-remote (only driver) mirror (93-02 with RPO D35) (no housing), RH = 12528881
Firebird half-remote (only driver) mirror (93-02 with RPO D35) (no housing), LH = 12528882
Firebird export breakaway all-remote mirror (93-97 with RPO DD9), RH = 10165476
Firebird export breakaway all-remote mirror (93-97 with RPO DD9), LH = 10165477
Camaro all-remote mirror (93-96 with RPO DG7 and UQ0/U62), RH = 10279357
Camaro all-remote mirror (93-96 with RPO DG7 and UQ0/U62), LH = 10279358
Camaro all-remote mirror (93-96 with RPO DG7 and U82/U65), RH = 10279359
Camaro all-remote mirror (93-96 with RPO DG7 and U82/U65), LH = 10279360
Camaro all-remote mirror (97-02 with RPO DG7), RH = 10279357
Camaro all-remote mirror (97-02 with RPO DG7), LH = 10279358
Camaro half-remote (only driver) mirror (93-02 with RPO D35), RH = 10279331
Camaro half-remote (only driver) mirror (93-02 with RPO D35), LH = 10279332
Camaro export breakaway all-remote mirror (93-98 and early 99, with RPO DD9), RH = 10423961
Camaro export breakaway all-remote mirror (93-98 and early 99, with RPO DD9), LH = 10423962
Camaro export breakaway all-remote mirror (00-02 and later 99, with RPO DD9), RH = 10428099
Camaro export breakaway all-remote mirror (00-02 and later 99, with RPO DD9), LH = 10428100
Camaro export breakaway all-remote mirror (97-02 with RPO DD9 and Z5X), RH = 10296900
Camaro export breakaway all-remote mirror (97-02 with RPO DD9 and Z5X), LH = 10296901
ACW is offline
Old 06-15-2005, 01:08 AM
ACW
ACW's Avatar
Default Body
Camaro SS hood (98-02) = 12369963
Camaro SS hood scoop grille screen (98-02) = 12369964
Camaro hood insulator (93-97) = 10278015
Camaro hood insulator retainer (93-97) = 20064875
Camaro hood support struts (93-97) = 10138515
Firebird WS6 hood (98-02) = 12455210
Firebird hood support struts (93-97) = 10201454
Camaro front fascia (93-97) = 10248139
Camaro front fascia (98-02) = 12335525
Camaro front grille (98-02) = 10280356
Camaro front fender (93-97), RH = 10284966
Camaro front fender (93-97), LH = 10284967
Firebird front license plate cover with bird = 10276353
Trans Am front fascia (93-97) = 10242397
Firebird front bumper fascia center support (98-02) = 10277922
Camaro front bumper fascia center support (98-02) = 10276561
front fascia deflector (93-97 Firebird), RH = 10246272
front fascia deflector (93-97 Firebird), LH = 10246273
front fascia deflector (98-02 Firebird, 93-02 Camaro), RH = 10297290
front fascia deflector (98-02 Firebird, 93-02 Camaro), LH = 10297291
Firebird front wheel well liner (98-02), RH = 10296523
Firebird front wheel well liner (98-02), LH = 10296524
Camaro front wheel well liner (98-02), RH = 10296525
Camaro front wheel well liner (98-02), LH = 10296526
Firebird front fender (93-97), RH = 10404898
Firebird front fender (93-97), LH = 10404899
Firebird W68 rocker panel molding kit (93-02), RH = 12369003
Firebird W68 rocker panel molding kit (93-02), LH = 12369004
Trans Am rocker panel molding kit (93-02), RH = 12517222
Trans Am rocker panel molding kit (93-02), LH = 12517223
Firebird Body Extension Package (from 97 W68 and Firebird GT) = 12371055
Firebird Body Extension Package (from 98-02 W68 and Firebird GT) = 12495402
Camaro Body Extension Package (from 97 Camaro F1) = 12363915
Camaro Body Extension Package (from 98-02 Camaro F1) = 12495399
Camaro rear bumper fascia (cover) = 12335528
Firebird and Formula rear bumper fascia (cover) (93-02) = 10201177
Trans Am rear bumper fascia (cover) (93-02) = 10201178
Firebird rear bumper impact bar (98-02) = 10294219
rear bumper fascia retainer (push-in) (22.5mm long) (need 6 of these) (93-02) = 5973400
Camaro rear quarter panel (93-02 coupe), RH = 12512748
Camaro rear quarter panel (93-95 coupe), LH = 12512749
Camaro rear quarter panel (96-02 coupe), LH = 12369981
Camaro rear quarter panel (94-02 convertible), RH = 12529167
Camaro rear quarter panel (94-02 convertible), LH = 12369983
Firebird rear quarter panel (93-02), LH = 12369980
Firebird rear quarter panel (93-02), RH = 12512750
quarter panel upper applique (93-02 coupe), RH = 10240164
quarter panel upper applique (93-02 coupe), LH = 10240165
quarter window folding top filler (93-02 convertible), RH = 10286318
quarter window folding top filler (93-02 convertible), LH = 10286319
Camaro rear spoiler (from 97-02 Camaro F1) (decal and 3-piece spoiler) = 12363940
Camaro SS rear spoiler (98-02) = 12369968
Camaro hatch support struts (98-02 coupe), RH = 10419988
Camaro hatch support struts (98-02 coupe), LH = 10419989
Camaro hatch support struts (98-02 convertible), RH and LH = 10193275
ACW is offline
Old 06-15-2005, 01:09 AM
ACW
ACW's Avatar
Default Brakes
standard front disc brake pads kit (98) = 18026165
Durastop front disc brake pads kit (98-02) (AC-Delco #17D749M) = 18038574
front disc brake caliper pin seal (rubber boot) (98-02) = 18026151
rear disc brake caliper bracket (93-97), RH = 18019858
standard rear disc brake pads kit (98-02) (AC-Delco #171-804) = 12454972
Durastop rear disc brake pads kit (98-00) (AC-Delco #17D750M) = 18039835 or 18038575
rear brake backing plate (e-brake assembly) (98-02, with TCS - RPO NW9), LH = 10434794
rear brake backing plate (e-brake assembly) (98-02, with TCS - RPO NW9), RH = 10434795
rear brake backing plate (e-brake assembly) (98-02, no traction control), LH = 10434796
rear brake backing plate (e-brake assembly) (98-02, no traction control), RH = 10434797
rear brake service kit (98-02 without positraction) = 12454994
rear disc brake caliper kit (98-02), LH = 12455127
rear disc brake caliper kit (98-02), RH = 12455128
Delco Durastop rear disc brake rotor (cross-drilled, slotted) (from Corvette), RH = 88926733
Delco Durastop rear disc brake rotor (cross-drilled, slotted) (from Corvette), LH = 88926734
rear drum brake rotor (98-02) (AC-Delco #177-857) = 18060239
brake fluid reservoir cap = 18060186
rear wheel speed sensor (93-02, no traction control) = 10456115
rear wheel speed sensor (95-97, with TCS - RPO NW9) = 10456264
rear wheel speed sensor (98-02, with TCS - RPO NW9) = 10456535
ACW is offline
Old 06-15-2005, 01:10 AM
ACW
ACW's Avatar
Default Convertible
blue convertible top (from 99 30th Anniv TA) = 10415193
convertible top cover, side extensions, graphite (94-99), RH = 10294888
convertible top cover, side extensions, graphite (94-99), LH = 10294889
convertible top cover, side extensions, neutral (96-02), RH = 10294890
convertible top cover, side extensions, neutral (96-02), LH = 10294891
convertible top cover, side extensions, ebony (00-02), RH = 10431845
convertible top cover, side extensions, ebony (00-02), LH = 10431846
convertible top cover, center piece, graphite (94-99) = 10294886
convertible top cover, center piece, neutral (96-02) = 10294887
convertible top cover, center piece, ebony (00-02) = 10431843
convertible top cover, storage bag (94-02) = 10193284
convertible top cover, latch panel (only avail. as graphite) (94-02) = 10246558
convertible top cover, latch (94-02) = 10225726
convertible top cover, nut for latch release link (need 2) (94-02) = 10493869
convertible top cover, pushbutton for latch release, neutral (96-02) = 10276436
convertible top cover, pushbutton for latch release, graphite (94-99) = 10225727
convertible top cover, pushbutton for latch release, ebony (00-02) = 10431844
ACW is offline
Old 06-15-2005, 01:11 AM
ACW
ACW's Avatar
Default Emblems/Badges
Trans Am door emblem (98-02), white = 10193489
Trans Am door emblem (98-02), silver = 10251107
Trans Am door emblem (98-02), pewter = 10400683
Trans Am door emblem (98-02), gold = 10287124
Trans Am door emblem (98-02), green = 10277575
Trans Am door emblem (98-02), teal = 10285856
Trans Am door emblem (98-02), medium quasar blue (20U) = 10296383
Trans Am door emblem (98-02), navy blue (28U) = 10287123
Trans Am door emblem (98-02), purple = 10277653
Trans Am door emblem (98-02), black = 10193490
Trans Am door emblem (98-02), bright red (81U) = 10193493
Trans Am door emblem (98-02), cayenne red (96U) = 10265867
Trans Am door emblem (98-02), maple red malachite (44U) = 10413017
Trans Am door emblem (98-02), medium patriot red (71U) = 10426727
Trans Am door emblem (98-02), yellow (from 02 CETA) = 10305321
Formula door emblem (98-02), white = 10285036
Formula door emblem (98-02), silver = 10285037
Formula door emblem (98-02), pewter = 10400684
Formula door emblem (98-02), gold = 10285042
Formula door emblem (98-02), green = 10285040
Formula door emblem (98-02), teal = 10297558
Formula door emblem (98-02), medium quasar blue (20U) = 10296385
Formula door emblem (98-02), navy blue (28U) = 10285039
Formula door emblem (98-02), purple = 10285045
Formula door emblem (98-02), black = 10285041
Formula door emblem (98-02), bright red (81U) = 10285044
Formula door emblem (98-02), cayenne red (96U) = 10297581
Formula door emblem (98-02), maple red malachite (44U) = 10413019
Formula door emblem (98-02), medium patriot red (71U) = 10426728
Firebird door emblem (98-02), white = 10285046
Firebird door emblem (98-02), silver = 10285047
Firebird door emblem (98-02), pewter = 10400685
Firebird door emblem (98-02), gold = 10285052
Firebird door emblem (98-02), green = 10285050
Firebird door emblem (98-02), teal = 10297557
Firebird door emblem (98-02), medium quasar blue (20U) = 10296387
Firebird door emblem (98-02), navy blue (28U) = 10285049
Firebird door emblem (98-02), purple = 10285055
Firebird door emblem (98-02), black = 10285051
Firebird door emblem (98-02), bright red (81U) = 10285054
Firebird door emblem (98-02), cayenne red (96U) = 10297580
Firebird door emblem (98-02), maple red malachite (44U) = 10413018
Firebird door emblem (98-02), medium patriot red (71U) = 10426729
Camaro front fascia emblem (red/white/blue lines with bowtie) = 10193494
Camaro front fascia Chevy bowtie = 10166783
Camaro Z28 front fender emblem, black = 10139552
Camaro front fender emblem (from 35th Anniv SS) = 10307879
Camaro black Z28 rear fascia emblem with red Chevy bowtie = 10154591
Camaro SS rear fascia emblem, red = 12369965
Camaro SS rear fascia emblem, silver = 12369966
Camaro RS rear fascia emblem = 12530095
Camaro silver infill letters (from 02 35th Anniv SS), front fascia = 10311824
Camaro silver infill letters (from 02 35th Anniv SS), rear fascia = 10308473
WS6 emblem, red = 12455216
WS6 emblem, blue (from 99 30th Anniv TA) = 12458777
WS6 emblem, black (from 02 CETA) = 88951585
WS6 'Ram Air' hood decal, white metallic = 12457574
WS6 'Ram Air' hood decal, blue (from 99 30th Anniv TA) = 12458403
Pontiac arrowhead emblem (from other vehicle), smaller = 10348686
Pontiac arrowhead emblem (from other vehicle), larger = 22658036
silver '5.7L' emblem (from GTO) = 92119040
silver square 'GM' emblem (from all 2005-up GM vehicles) = 15223484
black 'GT' emblem (good for Firebird GT) = 22636906
Firebird GT ornamentation package (from 97-02 GT) (dash plaque, 4 F.GT decals) = 12371047
Formula rear bumper fascia decal (from 93-97), white = 10208317
Formula rear bumper fascia decal (from 93-97), silver = 10221722
Formula rear bumper fascia decal (from 93-97), gray = 10269319
Camaro brake caliper decal (from 35th Anniv SS), LH front = 18046299
Camaro brake caliper decal (from 35th Anniv SS), RH front = 18046300
Camaro brake caliper decal (from 35th Anniv SS), LH rear = 88955422
Camaro brake caliper decal (from 35th Anniv SS), RH rear = 88955423
ACW is offline
Old 06-15-2005, 01:12 AM
ACW
ACW's Avatar
Default Tail Filler Panels
Firebird tail filler panel (from 93-97 Firebird V6) = 5977293
Firebird tail filler panel (from 93-97 Formula) (plain black - no logo) = 5977294
Firebird tail filler panel (from 94 25th Anniv TA) (white logo) = 5977296
Firebird tail filler panel (from 93-94 Trans Am) = 5978095
Firebird tail filler panel (from 95-97 Firebird 3800 GT V6) = 5978095
Firebird tail filler panel (from 95-98 Trans Am) = 5977286
Firebird tail filler panel (from 99 Trans Am) = 5978095
Firebird tail filler panel (from 99 30th Anniv TA) (white logo) = 16525477
Firebird tail filler panel (from 00-02 Trans Am) = 5977286
Firebird tail filler panel (from 02 CETA) (silver logo) = 10312725
ACW is offline
Old 06-15-2005, 01:13 AM
ACW
ACW's Avatar
Default Stripes
Camaro red stripes package (93-97) (from 97 Camaro F1 coupe) = 12363732
Camaro gold stripes package (93-97) (from 97 Camaro F1 coupe) = 12363733
Camaro silver stripes package (93-97) (from 97 Camaro F1 coupe) = 12363734
Camaro black stripes package (93-97) (from 97 Camaro F1 coupe) = 12363735
Camaro red stripes package (93-97) (from 97 Camaro F1 convertible) = 12363736
Camaro gold stripes package (93-97) (from 97 Camaro F1 convertible) = 12363737
Camaro silver stripes package (93-97) (from 97 Camaro F1 convertible) = 12363738
Camaro black stripes package (93-97) (from 97 Camaro F1 convertible) = 12363739
Camaro black stripes package (from 98-02 Camaro F1 coupe) = 12495400
Camaro silver stripes package (from 98-02 Camaro F1 coupe) = 12495401
Camaro 35th Anniv stripes, upper front fascia (both LH and RH together) = 10307873
Camaro 35th Anniv stripes, lower front fascia (both LH and RH together) = 10307874
Camaro 35th Anniv stripe, hood RH = 10307866
Camaro 35th Anniv stripe, hood LH = 10307867
Camaro 35th Anniv stripe, trunk/deck lid LH (convertible) = 10310679
Camaro 35th Anniv stripe, trunk/deck lid RH (convertible) = 10310678
Camaro 35th Anniv stripe, trunk/deck lid LH (coupe) = 10307875
Camaro 35th Anniv stripe, trunk/deck lid RH (coupe) = 10307876
Camaro 35th Anniv stripe, spoiler LH = 10307877
Camaro 35th Anniv stripe, spoiler RH = 10307878
Camaro 35th Anniv black hood scoop applique = 10308472
Firebird black stripes package (93-97) (from 97 Firebird GT) = 12371045
Firebird silver stripes package (93-97) (from 97 Firebird GT) = 12371046
Firebird black stripes package (from 98-02 Firebird GT) = 12495403
Firebird silver stripes package (from 98-02 Firebird GT) = 12495404
Firebird blue hood stripe (from 99 30th Anniv TA), LH = 10401297
Firebird blue hood stripe (from 99 30th Anniv TA), RH = 10401292
Firebird blue rear roof stripe (from 99 30th Anniv TA) = 10401984
Firebird blue trunk/deck lid stripe (from 99 30th Anniv TA) = 10401294
Firebird blue spoiler stripe (from 99 30th Anniv TA) = 10401296
Firebird black/silver hood stripe (from 02 CETA), LH = 10305315
Firebird black/silver hood stripe (from 02 CETA), RH = 10305316
Firebird black/silver front door stripe (from 02 CETA), LH = 10305317
Firebird black/silver front door stripe (from 02 CETA), RH = 10305318
Firebird black/silver quarter panel stripe (from 02 CETA), LH = 10305319
Firebird black/silver quarter panel stripe (from 02 CETA), RH = 10305320
ACW is offline
ACW
ACW's Avatar
Default L36 3800 V6 Engine
3800 camshaft (95-01) = 24505811
3800 cylinder heads (95-01) = 24508132
3800 rocker bolt = 24503515
3800 throttle body (95-98 auto trans) = 24503386
3800 throttle body (96-98 manual trans) = 24503387
3800 throttle body (99-01 all) = 24507244
3800 MAF screen (95-01) = 24503677
3800 195-degree thermostat (95-97) (AC Delco #131-115) = 24506986
3800 180-degree thermostat (98-01) (AC Delco #131-120) = 24505924
3800 idle air control valve (95-98) = 17112929
3800 oil pressure sending unit (95-02) = 24505969
3800 throttle body gasket (95-98) = 24503432
3800 thermostat gasket = 24502433
3800 upper/lower intake gasket kit = 12537616
3800 timing cover gasket = 24502252
3800 intake air temperature (IAT) sensor = 12160244
3800 IAT grommet = 24504388
3800 IAT wire extension (use with aftermarket CAI) = 24529241
3800 exhaust header (00-02), LH = 24507680
3800 exhaust header (00-02), RH = 24507682
3800 exhaust heat shield (00-02), LH = 24507677
3800 exhaust heat shield (00-02), RH = 24507678
3800 exhaust manifold gasket (FelPro-MS #95811) = 24507676
ACW is offline
Old 06-15-2005, 01:14 AM
ACW
ACW's Avatar
Default Camshafts
LT1 stock cam sprocket (93-94) = 10128349
LT1 stock cam sprocket (95-97) = 10206039
LS1 'Hotcam' camshaft = 12480033
LS1 ASA camshaft = 12480110
LS1 'roller' camshaft = 88958606
LS1 camshaft (from 98-00 F-body) = 12560965
LS1 camshaft (from 98-99 Corvette) = 12560964
LS1 camshaft (from 00 Corvette) = 12560968
LS1 camshaft (from 01 F-body and 01 Corvette) = 12561721
LS6 camshaft (from 01 Corvette Z06) = 12560950
LS6 camshaft (from 02-04 Corvette Z06) = 12565308
LS1 camshaft position sensor (with seal) (98) (AC-Delco #213-355) = 12560229
LS1 camshaft position sensor (with seal) (99-02) (AC-Delco #213-363) = 12561311
LS1 camshaft pstn. sensor connector (3-way black F) (98-02) (AC-Delco #PT117) = 12085495
ACW is offline
Old 06-15-2005, 01:15 AM
ACW
ACW's Avatar
Default Cylinder Heads
LT4 cylinder heads = 12363287 assembled, 12555690 casting
LS1 cylinder heads (98 F-body, 98 Corvette) = 12558807
LS1 cylinder heads (99-01 F-body, 99-01 Corvette) = 12559855
LS6 cylinder heads (01 Corvette) = 12560801
LS6 cylinder heads (CNC-ported, milled .055) = 88958622
LS6 cylinder heads with valves and springs = 12564824
LS1 cylinder head gaskets (98-01 F-body, 97-01 Corvette), pair = 12498543
LS6 cylinder head gaskets (MLS) (02 F-body, 02-04 Corvette), single = 12573949
LS6 cylinder head gaskets (MLS) (02 F-body, 02-04 Corvette), pair = 12498544
LS1/LS6 cylinder head bolts kit (15 bolts, for 1 head) (98-02) = 12498545
discontinued racing cylinder head = 12480005
racing cylinder head = 12480090
LS1 head guides = 12558081
6.0L head gasket = 12589227
LS6 valley cover = 12568002
ACW is offline
Old 06-15-2005, 01:17 AM
ACW
ACW's Avatar
Default Valvetrain
LT1 hydraulic roller lifter (93-95) = 5234890
LT1 hydraulic roller lifter (96-97) = 17120735
LT4 valve cover, LH = 12552321
LT4 valve cover, RH = 12552322
LT4 valve cover gasket = 10108625
LT4 valve cover mounting nut = 10108675
LT4 valve cover mounting stud = 10108674
LT4 valve cover mounting stud grommet = 10108626
LT4 valve cover PCV grommet = 10240678
LT4 valve cover oil cap = 12555685
LT4 valve stem seals, intake = 10212810
LT4 valve stem seals, exhaust = 12564853
LT4 valve shim (single) = 10212809
LT4 valve retainers (set of 16) = 12495492
LT4 high performance valve spring (single) = 12551483
LT4 high performance valve spring (set of 16) = 12495494
LT4 valve locks (set of 32) = 12495503
LT4 intake valve (2.00" diameter) (from 1996 350 LT4 Corvette) = 12555331
LT4 exhaust valve (1.55" diameter) (from 1996 350 LT4 Corvette) = 12551313
LS1 rocker arm bolts (m8x1.25 threads) = 12560961
LS1 valve cover (98), LH = 12559604
LS1 valve cover (99-00), LH = 12570427 (formerly 12559894)
LS1/LS6 valve cover (01-02), LH = 12570427 (formerly 12561820)
LS1 valve cover (98), RH = 12559603
LS1 valve cover (99-00), RH = 12582224 (formerly 12561819)
LS1/LS6 valve cover (01-02), RH = 12582224 (formerly 12561818)
LS1 valve cover gasket (98) = 12556429
LS1 valve cover gasket (99-02) = 12560696
LS1 valve stem seals (set of 8), intake (black) = 12533586
LS1 valve stem seals (set of 8), exhaust (brown) = 12457652
LS6 valve spring (02-04 Corvette) = 12586484 (formerly 12565313)
LS6 valve spring retainers = 10166344
LS6 valve locks = 10166345
LS6 valve spring (used with 12480033 hotcam camshaft) = 12565117
LS6 valve spring (used with 88598606 roller camshaft) = 12565313
LS6 hollow-stem intake valve (used with 88598606 roller cam) = 12565311
LS6 hollow-stem sodium-filled exhaust valve (for 88598606 roller cam) = 12565312
magnesium valve cover (only for racing heads 12480005, 12480090) = 12480025
LS1/LS6 pushrod = 10238852
LSx lifter = 17122490
ACW is offline
Old 06-15-2005, 01:19 AM
ACW
ACW's Avatar
Default Pistons/Internals and Crankshaft
LT1 knock module (from 93-95 F-body) (AC-Delco #213-96) = 16177700 (formerly 10456126)
LT1 knock module (from 96-97 F-body) (AC-Delco #213-325) = 16214661 (formerly 10456287)
LT1 knock module (from 95 Impala SS) = 16188309
LT1 knock module (from Impala) = 16214691
LT1 knock module (from Corvette) = 16214671
LT4 knock module (from Corvette) = 16214681
LT1/LT4 'extreme duty' timing chain kit (for 95-97) = 12370835
LT1 crankshaft position sensor (96-97) (AC-Delco #213-314) = 10456534
LT1 crankshaft position sensor seal (96-97) (AC-Delco #219-194) = 10476885
LS1 knock sensor (AC-Delco #213-298) (GP Sorensen KS116) = 10456222
LS1 knock sensor wiring harness = 12597415
LS1 piston ring kit (standard) = 88984247 (formerly 12533556)
LS1 piston ring kit (.250mm o.s.) = 88894300 (formerly 12453325)
LS1 piston assembly (98-02) = 88984245
LS1/LS6 timing chain damper = 88958607
LS1/LS6 stock timing chain = 12552954
LS1/LS6 heavy-duty timing chain (thicker alloy steel sideplates) = 88958608
LS1/LS6 crankshaft trigger timing ring = 12559353
LS1/LS6 crankshaft assembly = 12559354 (casting 12552216)
LS1/LS6 connecting rods = 12568734
LS6 connecting rod bolts = 12568069
LS1 front cover/crankshaft main seal (older design, hard to push in) = 12561244
LS1 front cover/crankshaft main seal (newer design, easy to push in) = 12585673
LS1/LS6 rear cover main seal = 12585671
LS1 rear main cover = 12572014
LS1 rear cover gasket = 12574293
LS1 front cover gasket = 12574294
LS1 crankshaft pulley/balancer bolt (m16x2x103mm) = 12557840
LS1 crankshaft balancer key (length 37.5mm, width 4.77mm) = 12561513
crankshaft position sensor (CPS) = 12560228
ACW is offline
Old 06-15-2005, 01:20 AM
ACW
ACW's Avatar
Default Cooling
LT1 steam pipe behind heads (93-94) (includes bolts, seals, hose to radiator) = 10108635
LT1 steam pipe behind heads (95-97) (includes bolts and seals) = 12556260
LT1 coolant steam pipe seals (93-97) = 10108689
LT1 coolant steam pipe bolts (93-97) = 12552974
LT1 water pump (93-97) = 12527741
LT1 water pump drive shaft o-ring (93-97) = 12553792
LT1 water pump gasket (93-97) = 10128343
LT1 air bleed valve (screw) (93-97) = 10070107
LT1 heater hose assy (93-94) = 10236039
LT1 heater hose assy (95-97) = 10261147
LT1 radiator (fits A4 and M6) (93-97) = 52466004
LT1 coolant elbow (RH bottom of throttle body) (95-97) = 12553625
LT1 coolant temp sensor- gauge (cyl head) (AC-D #213-77) (93-97) = 25037332 (f. 10096151)
LT1 coolant temp sensor- PCM (pump) (AC-D #213-310) (93-97) = 15326386 (form. 12146312)
engine coolant level indicator module/sensor (93) = 10195576
engine coolant level indicator module/sensor (8-way plug) (94-95) = 12135027
engine coolant level indicator module/sensor (2-way plug) (94-99) = 10096163
cooling fan motor (93-95 - with RPO C60) (AC-Delco #15-8563) = 22137319
cooling fan motor (96-02 - with RPO C60) (AC-Delco #15-8404) = 22104439
heater core (93-02) (AC-Delco #15-60051) = 52468039
heater core hose assembly (2 hoses) = 10415020
coolant resevoir cap (93-02) = 10188034
radiator drain plug (93-02) = 10368798 (formerly 52461346)
LS1 upper radiator hose (98-02 - without RPO V12 power steering cooler) = 10271554
LS1 lower radiator hose (98-02) = 10271555
LS1 radiator cap (98-02) = 10316828
LS1 water pump inlet with 195-degree thermostat (98-02) = 12571261
LS1/LS6 water pump (now same as LS2) (98-02) (AC-D #251-690) = 89017593 (f. 12458934)
LS1 water pump bolt (98-02) (m8x1.25x82.6, 31.8 thd, 17 od, GM7114M mzf) (need 6) = 12551926
LS1 coolant temperature sensor (98) (3-wire sensor: 2 for PCM, 1 for gauge) = 12551708
LS1 coolant temperature sensor (99-02) (2-wire) (AC-Delco #213-953) = 15326388
LS1 engine block heater = 12371540 (formerly 12367827)
LS1 rear coolant bolts (on back of heads) (HFH m6x1x30) = 11516425 (formerly 11514008)
LS1 coolant bolts for front pipe = 12561089
LS1 coolant crossover pipe = 12562169
LS1/LS6 coolant pipe (01-02) (need for installing LS6 intake manifold) = 12568478
LS1/LS6 coolant plug (01-02) (need 2) (need for installing LS6 intake manifold) = 12562788
inlet hose from power steering cooler to radiator = 10413567
LS1 throttle body coolant line 1 = 12556452
LS1 throttle body coolant line 2 = 12562165
ACW is offline
Old 06-15-2005, 01:22 AM
ACW
ACW's Avatar
Default Ignition
LT1 optispark (non-vented) (93-94) = 10457702
LT1 optispark (vented) (95-97) = 1104032
LT1 optispark o-ring (need 2) (95-97) = 10474278
LT1 optispark vent and vacuum harness (95-97) = 12555323
LT1 optispark distributor cap and rotor (95-97) (AC-Delco #D8301) = 10457293
LT1 optispark (non-vented) electrical harness (93-94) = 12106559
LT1 optispark (vented) electrical harness (95-97) = 12130319
LT1 coil (93) (AC-Delco #D535) = 1115315
LT1 coil (94-95) (AC-Delco #D573) = 10477208
LT1 coil (96-97) (AC-Delco #D577) = 10489421
LT1 spark plug wire set (93) (includes coil wire) = 12096417
LT1 spark plug wire set (94-95) (includes coil wire) = 12093439
LT1 spark plug wire set (96-97) (includes coil wire) = 12173592
LT1 coil wire (93-95) (AC-Delco #340R = 12096466
LT1 coil wire (96-97) (AC-Delco #346U = 12173578
LT1 ignition control module (93) (AC-Delco #D1971A) = 10483131
LT1 ignition control module (94-95) (AC-Delco #D1986A) = 10483139
LT1 ignition control module (96-97) (AC-Delco #579) = 10482803
LT4 starter = 10455709
LS1 spark plug wires, red (from C5 Corvette Z06) = 89017270
LS1/LS6 spark plug wires (98-02) (Style 8DDD, 7.8" long) (AC-Delco #348S) = 12192064
LS1 spark plugs (AC-Delco #41-985 platinum) = 12571164 or 12563707
LS1 coil (98-02) (AC-Delco #D580) = 12558948
LS1 coil bolt (m6x1x20, 9.8, pzor, 7114M, 14.2 flg od) = 11516423
LS1 coil stud (4 on RH, 5 on LH) (HFH, m6x1x40, special hd) = 12557539
LS1 coil bracket (99-00) = 12562864
LS1 coil bracket (01-02) = 12563288
ACW is offline
Old 06-15-2005, 01:23 AM
ACW
ACW's Avatar
Default Fuel
LT1 fuel filter (93-97) (AC-Delco #GF578) = 25121293
LT1 front flexible fuel supply lines (94-97) = 10258441
LT1 fuel pump relay (93-97) = 12193601
LT1 round retainer for fuel lines at side of throttle body (94-97) = 12048089
LT1 fuel injector (94-97) = 17124248
LT1 fuel rail kit with parts for return line (93-97) = 17113095
LT1 fuel rail (94-97), RH = 17113251
LT1 fuel rail seal kit (94-97) (AC-Delco #217-449) = 17113086
LT1 fuel rail crossover tube kit (94-97) = 17113092
LT1 fuel pressure regulator (93) (AC-Delco #217-370) = 17107491
LT1 fuel pressure regulator (94-95) = 17091221
LT1 fuel pressure regulator (96-97) = 17091947
LT1 fuel pressure regulator vacuum hose (94-97) = 10216948
LT1 fuel injector o-ring seal kit (94-97) (AC-Delco #217-1379) = 17113544
LT1 fuel tank (93-97) (metal, 15.5 gallons) = 10269093
LS1 fuel filter = 25121942
LS1 fuel injector (98) = 12533952
LS1 fuel injector (99-00) = 12456154
LS1/LS6 fuel injector (01) = 12482704
LS1/LS6 fuel injector (02, at 28#; used in Corvette Z06) = 12561462
LS1/LS6 fuel injector from C5R racecar (42# at LS1/LS6 58psi pressure) = 24508208
LS1 fuel tank filler hose (99-02) = 10409866
LS1 fuel tank filler pipe (99-02) = 10409867
LS1 fuel tank (98) (metal, 15.5 gallons) = 10293379
LS1 fuel tank (99-02) (plastic, 16.8 gallons) = 10422917
LS1 fuel tank pressure sensor assembly = 25323815
LS1 fuel pressure regulator = 12555909
LS1 fuel pump (98) = 253193351
LS1 fuel pump (99-02) = 25338871
LS1 fuel rails (98-02) (AC-Delco #217-1401) = 12562815
LS1 fuel rail cover (dual slots) (from 97-98 Corvette, black, red letters), LH = 12559261
LS1 fuel rail cover (dual slots) (from 97-98 Corvette, black, red letters), RH = 12556455
LS1 fuel rail cover (from 99-02 Corvette, black, red letters), LH = 12561503
LS1 fuel rail cover (from 99-02 Corvette, black, red letters), RH = 12561502
LS6 fuel rail cover (from 01-02 Corvette Z06, red, black letters), LH = 12564257
LS6 fuel rail cover (from 01-02 Corvette Z06, red, black letters), RH = 12564258
fuel line protectors (93-02) = 10232676
LS1 schrader valve at end of fuel rail = 25532663
Evap Control Valve (evaporative emissions canister purge solenoid valve) = 1997278
fuel tank filler door bumper (on door) (need 1 of these) (93-02) = 10172357
fuel tank filler door bumper (on pocket) (need 2 of these) (93-02) = 10257216
gas cap ('fuel tank filler cap') (93-97) (AC-Delco #GT174) = 10164142
gas cap (with tether) (98) (AC-Delco #GT222) = 22616291
gas cap (with long tether) (99-02) = 22616287 (discontinued for short version)
gas cap (with short tether) (99-02) (A-D #GT261) = 25757560 (form. 22660003, 22616286)
gas cap (without tether) (99-02) (AC-Delco #12F58) = ?
locking gas cap (99-02) (A-D #GT270 or 12F31L) = 22720375 (formerly 22660006, 22616294)
locking gas cap (98) - can use the above one, cut/grind down the tabs a little, should fit
ACW is offline
Old 06-15-2005, 01:25 AM
ACW
ACW's Avatar
Default Intake/Throttle
1LE intake bellows without silencer (93-97) = 25147187
1LE intake elbow (no vent hole for opti) (93-94) = 25147210
1LE intake elbow (for vented opti) (95-97) = 25147187
LT1 Intake Air Temperature (IAT) sensor (93-97) (AC-Delco #213-243) = 12160244
LT1 Mass AirFlow (MAF) sensor assembly (94-97) (AC-Delco #213-252) = 25008308
LT1 MAP sensor (93-97) (AC-D #213-1545) = 12569240 (formerly 16137039, AC-D #213-185)
LT1 MAP sensor seal (93-97) = 1635948
LT1 throttle control cable shield (cover on side of throttle body) (93-97) = 10260166
LT1 throttle cable (no traction control) (94-96) = 12550676
LT1 accelerator cable (no traction control) (97) = 12554852
LT1 throttle body cover and coolant plate gasket kit (94-97) = 17113074
LT1 throttle body upper cover and gasket kit (93-97) = 17112831
LT1 Idle Air Control (IAC) valve (without RPO KC4) (95-97) (AC-Delco #217-433) = 17113188
LT1 IAC valve (with RPO KC4 - oil cooler) (94-95) (AC-Delco #217-429) = 17113099
LT1 IAC/TB coolant housing (with gasket) (95) (with RPO KC4 - oil cooler) = 17113097
LT1 IAC/TB coolant housing (with gasket) (95-97) (without RPO KC4) = 17113187
LT1 TPS (Throttle Position Sensor) (includes screws) (93) = 17106682
LT1 TPS (Throttle Position Sensor) (94-97) = 17106680
LT1 CCV hose from throttle body to valve cover (94-97) = 10128365
LT1 top and bottom throttle body gaskets (94-97) (AC-Delco #40-743) = 17113074
LT1 stock 48mm throttle body gasket/seal (93-97) (AC-Delco #40-718) = 10105379
LS1 throttle cable (98-99, with traction control - RPO NW9) = 12552267
LS1 throttle cable (00-02, with traction control - RPO NW9) = 12563651
LS1 throttle cable (98-99, without TCS) = 12565559
LS1 throttle cable (00-02, without TCS) = 12565560
LS1 bracket for throttle cable and cruise control servo (98-02) = 12552865
LS1 throttle body (98-99 F-body) (small cam on throttle shaft end; brown spring) = 17113390
LS1 throttle body (00-02 F-body) (large cam on throttle shaft end; blue spring) = 17113647
LS1 throttle body (from 97-99 Corvette) = 17113564
LS1/LS6 throttle body (from 00-02 Corvette) = 17113669
LS1/LS6 stock 75mm throttle body gasket/seal (98-02) = 12552542
LS1 throttle body bolts (Hex Flanged Head, m6x1x30) (need 3) = 11516425 (formerly 11514008)
LS1 Idle Air Control (IAC) valve (kit with seal) (98-99) = 17113391
LS1 Idle Air Control (IAC) valve (kit with seal) (00-02) = 17113598
LS1 Intake Air Temperature (IAT) sensor (98-02) (AC-Delco #213-243) = 12160244
LS1 Mass AirFlow (MAF) sensor assembly (98-02) (AC-Delco #213-353) = 25179711
Delphi MAF sensor = 25318411
LS1 intake bellows = 25170358
LS1 support bracket for air filter (air filter housing) = 25166571
LS1 upper radiator support (holds the air filter support bracket / housing) = 25170361
LS1 upper radiator air baffle = 10409095
LS1 lower radiator air baffle = 10402723
LS1 intake manifold gasket set = 12524653
LS1 intake manifold, with EGR (98-00 F-body) = 12561269 (formerly 12560688)
LS1 intake manifold, no EGR (from 97-00 Corvette) = 88894095 (formerly 12557846, 12556333)
LS6 intake manifold (01-02 F-body) = 88894339 (formerly 88890524, 88890523, 12561184)
LS6 intake manifold (from Corvette Z06) = ? (formerly 12573572)
LS6 intake manifold gasket set (contains 8 gaskets) = 12533587
LS6 intake manifold bolt = 12552344
LS6 intake manifold seal = 12560251
Cold Air Induction Package (same as SLP Cold Air Induction) (from 97 Firebird GT) = 12371043
LS6 Manifold Absolute Pressure (MAP) sensor (with seal) = 16212460
LS6 MAP sensor seal = 16194007
1-bar MAP sensor (AC-Delco #213-1545) = 12569240 (formerly 16137039, AC-Delco #213-185)
2-bar MAP sensor (AC-Delco #213-1520) = 12569241 (formerly 16040609, AC-Delco #213-184)
3-bar MAP sensor (AC-Delco #213-1562) = 12223861 (formerly 16040749, AC-Delco #213-101)
pigtail harness for MAP sensor (AC-Delco #PT1035) = 15305891
ACW is offline
Old 06-15-2005, 01:26 AM
ACW
ACW's Avatar
Default Engine Oil
LT1 oil dipstick tube (93-94) = 12551831
LT1 oil dipstick tube (95-97) = 12551154
LT1 oil dipstick (93-94) = 10232187
LT1 oil dipstick (95-97) = 12551144
LT1 oil pan (93-97) = 93442037 (formerly 12557557)
LT1 oil pan gasket (93-97) = 10108676
LT1 oil pump screen 3/4" tube = 12550042 (formerly 12555283)
LT1 white oil pump spring = 3848911
LT1 low oil level sensor (includes seal) (93-97) = 12579985 (formerly 24507190)
LT1 low oil level sensor seal (93-97) = 10151633
LT1 oil pressure sensor (93, some 94) = 24575127
LT1 oil pressure sensor (95-97, some 94) = 10201491
LT1 oil pressure sensor angle fitting (94-97) = 10137636
LT1 oil pump drive assembly (93-97) = 1103868
LS1 F-body oil pan = 12558762
LS1 F-body oil pan gasket = 10108676
LS1 oil pan rear bolts (10mm) = 12554990
LS1 F-body oil pump pickup = 12558251
LS1 F-body windage tray = 12558253
LS1 F-body oil dipstick = 12551581
LS1 F-body oil dipstick tube (with o-ring seal) = 12551577
LS1 F-body oil dipstick tube mounting bolt (m10x1.25x25) = 11515765
LS1 oil drain plug = 24100042
LS1 oil pressure sending unit (sensor) (98) = 12559781
LS1 oil pressure sending unit (sensor) (99-02) = 12562267
LS1 oil level sensor (with seal) = 24507190
LS1 front oil gallery plug (front of block, next to oil pump) = 09427693
LS1 rear oil gallery plug (to the left of the crank) = 12558340
LS1 oil filler tube (with o-ring seal) = 12559505
LS1 standard oil filler cap = 24504599
LS1 oil filler cap with Mobil 1 logo = 12555685
LS1 Mobil 1 oil spec sticker = 10236268
LS1 oil filter (98-02) (AC-Delco #PF44C) = 729854
LS1 oil filter (98-02) (AC-Delco #PF44) = 25010633
LS1 oil filter (98-02) (AC-Delco #SPF44) = 25329388
LS1 oil filter (98-02) (AC-Delco #UPF44) = 25329389
LS1 oil pump o-ring seal = 12557075
LS6 oil pump o-ring seal = 12557752
LS6 oil pump (replaces LS1 pump) = 12586666 (formerly 12586665, 12563964, 12556436)
ACW is offline
Old 06-15-2005, 01:28 AM
ACW
ACW's Avatar
Default Exhaust
LT1 O2 oxygen sensor (93) (non-heated) (AC-Delco #AFS21) = 25166816
LT1 O2 oxygen sensor (94-95) (heated) = 25312184
LT1 O2 oxygen sensor (96-97) (rear heated) (AC-Delco #AFS97) = 25312196
LT1/LT4 EGR gasket (AC-Delco #219-21) = 12337972
LT1 EGR pipe/tube gasket = 10055726
LT1/LT4 EGR block-off plate = 10054880
LT1 exhaust manifold gasket (93-97) = 12552469
LT1 exhaust manifold to y-pipe studs (93-97) = 10220453
LT1 exhaust manifold to y-pipe nuts (93-95) = 11516072
LT1 exhaust manifold to y-pipe nuts (flanged) (96-97) = 10255857
LT1 catalytic converter (95 California) = 12555496
LT1 catalytic converter (93-95) (3-way) = 10230431
LT1 catalytic converter (96-97) = 12560407
LT1 catalytic converter (96-97, RPO NM8 - leaded fuel) = 12560408
LT1 catalytic converter (96 export) = 12555502
LS1/LS6 header flanges = 12480130
LS1 EGR gasket (98-00) (EGR to exhaust manifold graphite gasket) = 12553047
LS1 EGR O-ring (98-00) = 12557932
LS1 EGR block-off plug = 12558346
LS1 exhaust manifold (98-99), RH = 12560193
LS1 exhaust manifold (98-99), LH = 12560194
LS1 exhaust manifold (00), RH = 12559506
LS1 exhaust manifold (01), RH = 12567706
LS1 exhaust manifold (00-01), LH = 12559507
LS1 exhaust manifold gasket = 12558573
LS1 exhaust muffler hanger (98-02) = 10407350
V6 Cat-Back Performance Exhaust Package (304 stainless steel, B&B) (96-97 V6) = 12371042
LS1 WS6 exhaust muffler with tail pipe (single) (98 WS6), with polished tip = 10436321
LS1 WS6 exhaust muffler with tail pipe (single) (98 WS6), with non-polished tip = 10409537
LS1 SS dual/dual exhaust (98-02), with polished tips = 10421501
LS1 SS dual/dual exhaust (98-02), with non-polished tips = 10414653
LS1 y-pipe bracket for automatic trans = 10270117
LS1 y-pipe bracket for manual trans = 10284835
LS1 O2 oxygen sensor (98-02) (AC-Delco #AFS97), both RH = 25312196
LS1 O2 oxygen sensor (98-02) (AC-Delco #AFS98), both LH = 25312197
LS1 long rear O2 sensor (from 02 Corvette) (Bosch #13111, AC-Delco #213-810) = 25317697
LS1 catalytic converter (98 export Camaro) = 12560410
LS1 catalytic converter (99 export Camaro) = 12559778
LS1 catalytic converter (98-99 Camaro), RH (no LH) = 12559244
LS1 catalytic converter (00-02 Camaro), RH (no LH) = 12562398
LS1 catalytic converter (98 Firebird), RH (no LH) = 12559244
LS1 catalytic converter (99 Firebird), LH = 12559245
LS1 catalytic converter (00-02 Firebird), LH = 12562397
LS1 catalytic converter (99-02 Firebird), RH = 12562398
LS1 catalytic converter gasket (between cat and manifold) (98-02), LH = 12555806
LS1 catalytic converter gasket (between cat and manifold) (98-02), RH = 88891747
LS1 Secondary Air Injection (AIR) check valve (98-99) (AC-Delco #214-419) = 22048212
LS1 Secondary Air Injection (AIR) check valve (00-02) (AC-Delco #214-1045) = 12565503
LS1 Secondary Air Injection (AIR) pipe gasket (98-02) = 12553617
LS1 Secondary Air Injection (AIR) pipe bolt (98-02) (m8x1.25x24.4, 20 thd) = 12556127
LS1 Vehicle Emission Control Information under-hood sticker (01-02) = 12564045
ACW is offline
Quick Reply: LT1/LT4 and LS1/LS6 F-Body Part Numbers
