Drag Racing Tech
5 Pt. Harness and seat
Old Jan 16, 2006 | 08:02 AM
Racer8102's Avatar
Default 5 Pt. Harness and seat
I just got done installing my 6 pt cage, and now I am wanting to put a lightweight seat and harness in, I am wondering what harnesses everyone is using that mount to the crossbar of the cage (floor on sides and front) and what seats are being used? Where to purchase them, and maybe even some pics of your setup. Thanks
Old Jan 16, 2006 | 03:52 PM
GM Muscle's Avatar
I run a Stroud cam lock harness. My shoulder straps wrap around the cross bar, my lap belts use the factory mounting points (had to open up the holes in the lap belt brackets alittle), and the sub belt is wraped around a Wolfe crotch strap bracket. This way I didn't have to pop any holes in the car. I got my harness' from Wolfe Race Craft. I started with Corbeau seats but switched to Kirkeys, I actually just put them in today. If you go with Kirkeys, seat brackets will have to be fabricated.
I have an extra crotch strap bracket I'm looking to get rid of. Wanted $20 shipped if your intrested. Here's what they look like, they bolt to the factory seat bracket studs. http://www.wolferacecraft.com/detail.aspx?ID=252 .
Old Jan 16, 2006 | 06:17 PM
Racer8102's Avatar
Sent a PM, and I'll take the bracket
Old Jan 16, 2006 | 07:14 PM
ApacheDrill's Avatar
I run Simpson cam locks through Corbeau A4 seats and use the wolfe bracket for the crotch strap as well..
My helmet and Nomax jacket are Simpson and wanted them the match.. They are a little more pricey then some of the others..
Old Jan 16, 2006 | 10:27 PM
ty_ty13's Avatar
7 Second Club
G-force cam lock 5pnt
with aluminum kirkeys and padding
my daily driver with a loudmouth exhaust, th350, 4.10 gears, and no sound deadning.... **** my ears
Old Jan 17, 2006 | 01:42 PM
rebersole2's Avatar
I run a Simpson Belt (floor mount) ($65) through a Jegs hard black plastic seat with a black cover ($69). I've got one for each side, but have yet to put the passenger side seat in.
Old Jan 18, 2006 | 09:54 AM
Matt D's Avatar
Retired Street Racer
I had a Simpson cam lock until it was out of date. I now have a RCI cam lock harness with a JAZ seat. I am going back to stock cloth seats for daily driver comfort. Here is a pic of the JAZ seat and Simpson harness:
Old Jan 20, 2006 | 02:06 PM
NA$TY-TA's Avatar
Kirkey Seats and RJS Camlock harness's Pass and driver.....
Old Jan 20, 2006 | 08:43 PM
Racer8102's Avatar
Thanks for the info and the bracket (GM Muscle), I ordered my 5pt, but I think i'll keep the firebird seats for now. Since the search is still broke do any of you all have pics or suggestions on mounting the hawker 680 batt. and I also have one of the small plastic coolant overflow tanks (Summit brand) that I am wanting to use to replace my cracked factory coolant overflow tank. I am about to get all the little loose ends taken car of before we start racing this year. Thanks
Old Jan 20, 2006 | 10:28 PM
SUX2BU's Avatar
G force latch and Kirkey seats (more comfortable than stock).
