3rd Brake Light Mod Write up (For Bird Owners)
Old Feb 22, 2006 | 03:28 PM
DirtyBird222's Avatar
Default 3rd Brake Light Mod Write up (For Bird Owners)
edit.......look 2 post down
PM or E-mail me if you want this in a MS Word Format
Old Feb 22, 2006 | 03:31 PM
nasty99WS6's Avatar
not working for me.
Pontiac Trans Am: 3rd Brake Light Mod:
Step 1 Removal: You’ll want to get a T15 star style screwdriver such as the one pictured. This is required to unscrew the screws holding the 3rd Brake Light in place.
Step 2 Cleaning: You will want to clean the brake lens very well. A) Wipe down with some liquor thinner. B) Clean with hot water and automotive soap (mixed) let dry.
Step 3 Sanding: You do not have to do this step, but it is recommended that you at least scuff up the lens with wet sand using 1000 grit, just so the paint has a somewhat rough surface to stick to. I sanded down all the DOT lettering and numbers to give it a cleaner look. A) Wet sand with 800 grit; clean with hot soapy water, rinse with hot water. B) Wet sand with 1000 grit; clean with hot soapy water, rinse with hot water. Let dry
Step 4 Applying The Decal/lettering/ect.: Put the decal wherever you like, make sure the lens is clean and just a little wet when applying it if it is vinyl!
Step 5 Painting: Once you have sanded and applied the decal you should be all set for painting. I suggest to use a spray gun if you have one of get this painted professionally if not. But if you want use a rattle can. With your color of choice and some clear coat you are all set to start painting. Method I used, with a spray gun and black paint.
A) 3 coats of base. Wait at least 15 minutes between spraying each coat. Make sure you are in a dust free setting.
B) Apply as many coats of clear as you want. I applied 3 coats for an extra nice shine.
C) I let everything dry for a couple days before removing the decal.
D) Remove Decal. And wallllllaaaaH. You should have something similar to this! Hopefully!
Daytime (sorry for the crappy picture and dirty car. I sprayed a reflective clear coat before the base and before applying the decal. It looks pretty cool when a HID style light hits it. Unfortunately, I’m the only one with a car that is equipped with HID in my household! And I forgot to take pictures when I had this lit up by my HID fogs)
NIGHT TIME
Old Feb 22, 2006 | 03:50 PM
btw I can make the vinyl lettering for this and a couple of different style phoenixes
Old Feb 22, 2006 | 04:05 PM
thunder95ta's Avatar
Thanks for the info!!
Old Feb 23, 2006 | 12:56 AM
nhra-trans-am's Avatar
Here is mine.
Thanks again DirtyBird222
Old Feb 23, 2006 | 04:52 AM
dementia's Avatar
Thats awesome, both of yours. Thanks for the writeup. Im definitely going to do this to mine once I figure out what I want on there.
Old Feb 23, 2006 | 09:45 AM
that loosk awesome!
Old Feb 23, 2006 | 12:32 PM
BlackHawk T/A's Avatar
Originally Posted by nhra-trans-am
Aha, someone took my idea and ran with it I see
I want one!
Old Feb 23, 2006 | 03:41 PM
ThatGuySkye's Avatar
formerly mystic-t/a (changed 02/05/2013)
Here is mine, no lettering or anything, but I just hated the top part, plus it goes with my paint job.
Old Feb 23, 2006 | 06:48 PM
blackhawk if you want a sticker pm me! NHRAtransam was my first try at that style bird, but it came out really well!
Old Feb 24, 2006 | 02:10 AM
Hey nhra-trans-am,
Can you take a pic from behind the car, as other people would see it? I am curious if you could even make out what it was at all...
Old Feb 24, 2006 | 11:17 AM
blackhawkta you can def. see it from behind because I got pulled over for what mine says!
Old Feb 24, 2006 | 11:20 AM
Yeah but yours is much more obvious than the bird wings would be...
Old Feb 24, 2006 | 11:44 AM
TAbeba's Avatar
Nice Job! ill be doing this soon
Old Feb 24, 2006 | 02:11 PM
I will take pics today and post them tonight
Old Feb 25, 2006 | 01:29 AM
here are the pics
A little harder to see, but I can still tell it's a bird
Old Feb 25, 2006 | 04:44 AM
Not bad...would it be possible to get it made wider to use more of the light space?
Old Feb 25, 2006 | 07:48 AM
yes sir
Old Feb 25, 2006 | 07:54 AM
GotV-8's Avatar
http://www.fuelslut.net/hosting/uploads/starscrew.jpg
http://www.fuelslut.net/hosting/uplo...ht daytime.jpg
NIGHT TIME
http://www.fuelslut.net/hosting/uploads/fthis3rd.jpg
http://www.fuelslut.net/hosting/uplo...am3rdlight.jpg
What ive been waiting on. Thanks for a write up Dirtybird.
