BRracing garage sale, Race & Performance parts
2 sets billet aluminum LS6 type valvecovers, 1 nat. finish, the other red anondized. Both have extra oil/breather holes that may need to be plugged for your application 225.00 per set Nat. finish sold!
MMS Stage III LS6 Hyd Cyl. Heads. No flow#'s available, These heads with a 200hp shot went 9.31@ 145.8 mph on a full weight T/A, using a MMS 229 camshaft. These heads have maybe 30 passes on them. 1600.00
More Performance Stage III SR LS6 Heads. Have flow sheet And build sheet data.These are some of the highest flowing LS6 heads out there, and have all the goodies. Dyno tested only, No track passes & very little running time
Over 3400.00 invested, 2400.00
ATI- Sfi rated damper, No a/c pulley 200.00 SOLD!
Complete Cam Kit,
New Comp Cams Hyd. Roller (MTI S-1 Grind) .630/.630 244/244 114 LSA
3732R/3732R Lobes .360 Lobe Lift
Isky# 6205 Dual valvesprings w/damper 1.430 O.D.
Isky Titanium Retainers, Isky Spring Seats All New, 550.00
Used Comp Cams SR-Custom Grind 54-000-11
.690/.690 272/280 113 LSA .406 lobe lift Dyno use only- 275.00
Callies 4.00 Stroker Crankshaft, 2 damaged rod journals, needs repair but this is fairly cheap. 700.00
More Performance custom polished sheetmetal intake w/nitrous bungs.
Cost was over 2700.00 1900.00
Modified Holley 105mm Throttle body. Has LS1 type idle air control & tps 350.00
Used JBA shorty headers w/air tubes. Fits 99-02 Excellant cond. 225.00
Used SLP high flow radiator 190.00
Strange 31 spline axles w/ screw in 1/2 studs & bearings for stock width F-Body 12 bolt (4th Gen) 200.00
New cast aluminum deep trans pan for TH400 90.00
These parts are all from 2001 T/A with 1700 orig. miles:
4L60E Trans, no problems, perfect condition. 850.00
10 bolt housing & axles, Cast aluminum cover 125.00
Stock rear coil springs 50.00
Stock rear suspension parts 50.00 for all
Stock K-member 125.00
Complete Rack & Pinion w/outer tierod ends 200.00
Power steering pump 50.00 SOLD
A/C compressor 100.00 SOLD
8 LS1 Ignition coils 140.00
Stock 28lb injectors 80.00
New Hayes SB Flexplate # 10-010 35.00
New 2001 WS6 Hood, painted red w/decals, also finished on the underside.
Over 1900.00 invested in hood & paint/finish work 1100.00
Other parts available, call Buster@ 609-888-0300 or email portbuzz2@aol.com BUYER RESPONSIBLE FOR ALL SHIPPING & HANDLING CHARGES
Visa & MC accepted
Complete Cam Kit,
Visa & MC accepted
Originally Posted by brian89rs
Any pics on the nat. valve covers. And what brand are they. Thanks Brian
Buster
pic? i'll take it after a pic!! let me know, thanks
Buster
Originally Posted by reds10
Are the power steering pump and a/c compressor still available?? I need all brackets and accessories for an ls6 engine to be put into my s10. It's an 03 ls6 I'm pretty sure it's the same as the 01 t/a pm me
I won't be able to check on it till tomorrow am, the parts are all at my shop.
Buster
Originally Posted by 1a-play
interested in the crank -pm me with details of repairs needed
Buster
very intrested in the ati damper...money in hand...send me a pic to groundpoundinlt1@yahoo.com and consider it sold
thanks
bubba
thanks
bubba
thanks
bubba
thanks
bubba
Sorry, but I will be buying it once he sends me the pics tomorrow
I talked to him yesterday evening before anyone had even replied to the thread or talked to him about the balancer
If something falls through, I will let him know but as of right now, I'll be buying it
