FS: Interceptor Scan Gauge
I have for sale 1 interceptor Scan Gauge. Here is a little overview taken from their site on what it is.
The Interceptor is capable of displaying the following parameters, two at a time, at a
rate of approximately 20 times per second.
It can monitor the following.
RPM
MPH
Intake Air Temperature
Mass Air Flow Sensor Frequency
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width (bank 1 and 2 if supported)
Long Term Fuel Trim (bank 1 and 2 if supported)
Short Term Fuel Trim (bank 1 and 2 if supported)
O2 Sensor Voltage (bank 1 and 2 if supported)
Manifold Pressure in PSI (Boost pressure for factory
turbo/supercharger applications)
Ignition Advance
Knock Retard
Engine Run Time
Battery Voltage
Transmission Temperature
Idle air Control Counts
Throttle Position Percentage
Throttle Position Voltage
Engine Load
Oil pressure (some 8 cylinder engines)
Fuel economy (MPG)
Horspepower
Two user configurable analog inputs
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge
pods of this size. A 5' cable is included with appropriate OBD2 connector
Lights up red.
120.00 obo
RPM
MPH
Ignition Advance
Knock Retard
Engine Run Time
Battery Voltage
Engine Load
Fuel economy (MPG)
Horspepower
Lights up red.
120.00 obo
Originally Posted by cablebandit
not sure how CHIWS6 pm supercedes my first post here...what was the use of responding if its ignored.
Originally Posted by Nine Ball - Administrator
Due to some past issues with people replying to ads and calling "dibs", which is basically claiming all rights to a sale, we wish to post our policy on this subject.
"Calling dibs" isn't valid here. There are many reasons for this.
1. Seller has the ultimate right to sell to whoever he chooses, as well as the right to refuse to sell to someone for whatever reason.
2. Seller could have this item advertised in the regional forum, classified forum, and maybe 10 other websites and the local newspaper. Its impossible to claim "dibs" on a sale that you might not have seen first. You might be the first to reply in a thread, but that doesn't mean 10 people have already emailed the seller about it.
3. Calling "dibs" sometimes makes other potential buyers lose interest in the sale. This really sucks when the guy calling "dibs" is just a dreamer or is trying to lowball the seller, and ends up not buying the item. The other buyers will probably be long gone by then, and have bought similar items from someone else.
So, please keep in mind that "calling dibs" on something does NOT guarantee you the sale of the item. Therefore, do not waste your time calling dibs. Just send a PM or email to the seller and discuss things privately. Once your sale is 100% confirmed and you sent the funds, you may reply that it is sold to you.
Thanks.
Thanks.
