LS1 Lid Conversion pictures for those that want them "56k death..."
Old Nov 5, 2006 | 11:25 PM
jimbob's Avatar
Default LS1 Lid Conversion pictures for those that want them "56k death..."
LS1 Lid conversion on LT1 with stock hood....
You have to lay the radiator back almost until the upper radiator hose touches the ABS mounting plate (1/4 inch gap). Pull the condenser out of it's holding tabs and drop down. Tap down the top of the condenser. Bend the upper condenser hose to fit. Trim the radiator top. Trim the upper radiator support to fit your particular size air filter. Make some new holding straps/and or make a new cover. Cut the cross brace in the hood, just above where the Air intake will sit.
Lots of work for a stock type car...Hopefully I can get to the dyno this week and see what if any real gains on my 401 combo..I can already tell you, it does pull harder in the upper rpm ranges vs. my old Moroso CAI (could be due to better cold air affect though), and that the IAT's stay down to outside temp if you stay moving over 20mph.
Old Nov 5, 2006 | 11:45 PM
Lethal Z's Avatar
Fantastic pics and detail thanks. This should be posted as a sticky. Can you close your hood and is the hood stock?
Old Nov 6, 2006 | 12:01 AM
luckyou03's Avatar
sweet, thanks for the pics. what kind of intake manifold you running?
Old Nov 6, 2006 | 12:13 AM
jimbob's Avatar
Here's a video of my car "when it gets done optimizing" That shows the hood down...
http://video.ls1tech.com/video/c4956...710011aa9a.htm
I'll get those under hood pictures loaded maybe, tonight...
luckyou03
That's a custom "Speed Secrets" intake manifold. Ellis "twofast4lv" put it together. Welded behind runners, ported runners, ported threw the whole manifold. Top was cut and raised 2 inches. NO cross over tube hump in manifold
Old Nov 6, 2006 | 12:21 AM
Vaders94's Avatar
what is the black cover made of? i cant tell what you used to seal the lid?
Old Nov 6, 2006 | 12:35 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's definetly really sweet. Doesn't seem like it would be worth it though for a close to stock car though. You're 401 should like it a lot though.
Old Nov 6, 2006 | 01:08 AM
SStrokerAce's Avatar
You would be suprised, I've seen 25rwhp over the standard CAI with that setup on stock motors.
Bret
Old Nov 6, 2006 | 01:27 AM
daniel6718's Avatar
went from 12.20 to 12.05 spinning with just this change...same track...now add in a ram air from the for lights, ls1 guys say 1-3 tenth gain and 1-3 mph...im hoping for a mid to low 11.8
Old Nov 6, 2006 | 02:30 AM
Formula350's Avatar
Can't you use the radiator from the correct year to hot have to cut it up? All under a stock hood too
Your intake is NUTS! And that TB, who makes that? Is that just a Holley? Looks bigger heh. FULL OF questions
Old Nov 6, 2006 | 03:42 AM
jimbob's Avatar
Ls1 radiator is basically a thin core version of ours. So, yeah you would still need to cut the top...That's easy though. You can see, I cut a little too much on the far side (engine side) of the radiator, I could have left more. It's more than strong enough though....
The TB is an LPE/Accell. Back in the day (I'v had my stroker sense 1997) that's the only thing you could get. It's actually got a 3rd gen TPS plug that came with a kit from LPE, to convert our smaller "LT1 Plug" to that bigger 3rd gen plug.
Bret,
I hope to see some power out of it. I know Ellis could not get any traction with it after the 2/3 shift. He had to lift twice and had spinning problems off the line, like a 1.7 something 60 foot. The first day out this season it ran a 1.52. I'm sure it will 60 in the 1.4's next year with some time on it. Not bad for 3700+lbs....
Old Nov 6, 2006 | 03:51 AM
jimbob's Avatar
Thin tin. Ryan K (Fueling@Injection moderator) made a template out of card board. We laid it over the tin and just cut it out. The back lip area was bent with a 2X4 block of wood. Then we just painted black... I'm lucky to have Ellis (Speed Secrets), Ryan and Cory H (LS2 port works) in the same general area (it also helps were all on the same race team ).
Old Nov 6, 2006 | 06:55 AM
the_merv's Avatar
Looks good. I'll have to play with mine I guess..
Old Nov 6, 2006 | 09:26 AM
TwoFast4Lv's Avatar
We are real interested in the results. JimBob worked hard to get it all done. If it works as well as reported we will be converting the other shop car also
JimBob did an outstanding job. He worked on it for days to make sure it was just right.
Good Job Jim!
Old Nov 6, 2006 | 06:36 PM
hyperzone's Avatar
beautiful! I think I just posted on another thread asking for more pictures of your work - sorry. hehe.. Didn't see this thread till now. Its looks really good. I'll definitely be using yours as a reference for a rainy day project.
Old Nov 6, 2006 | 07:10 PM
FASTFATBOY's Avatar
Bret
Over a stock setup or a K&N CAI aftermarket, was this on a LT1 car?
David
Old Nov 6, 2006 | 09:05 PM
coldkillinTA's Avatar
what did you use for the tubing going from the TB-MAF?? is that a "smooth bellow" for an ls1? thanks
Old Nov 6, 2006 | 09:20 PM
jimbob's Avatar
That's just a straight 4 inch silicone hose that fits over the airlid then to my 85mm MAF. The other end of my MAF is a 4 inch to 4 inch hump hose. Fits real good and tight.
Old Nov 6, 2006 | 10:46 PM
David
Yes CAI... and LT1 car.
Old Nov 7, 2006 | 09:42 AM
steve40's Avatar
any ideas on how this would compare to the stock lt1 ram air?
Old Nov 7, 2006 | 10:17 AM
nemanracing's Avatar
Nice Pics, Good work!
